  • Replies 486
Posted Images
Lorenzo resigned with Yamaha a few weeks ago for two more years
And with MM coming up from Moto2, Dani is very disposable
Resigned and resigned; same spelling, different meaning!
5th was a good result for him but it took a poorly executed overtaking move by Hayden (who had Rossi well covered on race pace) to allow Rossi in front. This had the desired effect of splitting Rossi and Crutchlow who was being held up by Rossi.
He will be happy with the result but realistically with Stoner running off and the above happening he is still nowhere.
he was second in the rain at Le Mans, no?
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
