  • Replies 486
Posted Images
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!
You piece of shit traitor loser scumbag asshole. Stay in your shit team with your hack bike and off my TV screen you glory hungry pig
I hope lorenzo continues to fkn own you
Now im truley filthy that stoner is leaving. Why couldnt it have been you
http://wwos.ninemsn.com.au/article.aspx?id=8516780
Stoner let's loose! And rightfully so. Two years of broken promises and unfulfilled hopes
Bet he feels vidicated by their lack of any success whatsoever, especially after the shit thay talked about him
Damn shame he's retiring, honda will no doubt be ontop of these chatter issues by then, and he'd be sitting very pretty for years to come
stoner could have had so many more championships, but with a wife like he has why bother still racing? V8's next year with 888 red bull??
i hope rossi goes as bad as this year and maybe comes out of the closet??
A few massive high sides all in the same turn in quali from some of the top riders...Stoner first, suspected broken ankle but turned out to be a torn ligament
Spies went over on a lap where he was 5tenths up on the fastest lap...Pretty decent off but he went back out before the end of the session and was on the pace again
Hayden went down and looked to be KO'd on impact, but was concious when being loaded into the ambulance and gave a wave so should be right to race...
Dovi over to Ducati confirmed. Could be the best move he has ever done or the worst in his career. Bet he had to think about that one hard considering how everyone else is performing on the Ducati. Could it be another talented rider to taste the bitterness of the Ducati pig? Or can he pull something out of the bag?
Gonna be interesting to see indeed!
