Tinyest of updates from me
The 31 was off the road while i repaired a bit of rust (not 100% done because i couldn't get my hands on a mig)
Had to get some new rear tyres so was wearing stockies for a little bit
Saved some penies and bought some round things for the back
and some more pics of the shitter corolla
haha, for lolz (got a few paint pens on ebay, got bored after doing the tyre writing on 1 tyre so started attacking the engine bay)
also, out of picture is the "flux capacitor"
my housemate also painted the inside of the front mudflap fluro orange :glare:
im thinking the angle grinder might make an appearance sometime, but its already a pretty dodgy car (mainly dying gearbox and super worn bushes)
WTF is that on your gearbox :):D ? Is that a "pipster ockey clutch special" or am I seeing things here....
Haha, yep
Otherwise the clutch fork comes off the pivot ball and the clutch slave goes on an angle and the pedal gets heavy sometimes
Guess the guy that did the clutch for me f**ked something up,
meh, it works I guess
Pretty dodgy tho
yeam mine has the hectic black guards, and a ful sik HKS exhaust which seems to neither add power nor change the noise, just looks different.
Yours has been lowered a fair bit too I think, looks good.
Keeping the Stag as my weekender: but just put a deposit on a Toyota 86: due in December at this stage... :)
december really?? friend of mine has been on toyotas back about it. took one for a test drive on monday (which was an auto because the other person who booked in a test drive wanted auto......lame) and they told him 12 months wait time......seems a bit silly
this is pretty long gone now, but was fun while i had it
this is also gone now unfortunatly
but it made way for
:D i also had a 1983 series 2 nissan bluebird with a cA18det in it, but have no photos of it, they got burned in a fire :(
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
