So, me and "da boiz" are going to go, go karting some weekend soon.
In Sydney only ever been to Eastern Creek karts way back when i was like 10, so i was driving the slowest ones there. Since then, been to the one at phillip island 2 years ago and that was awsome. so if you can compare any of the sydney tracks to this, then please do so.
Point to the thread - Are there any better go kart places in Sydney than Eastern Creek ??????(in terms of value, track awsomness and speed of karts)
https://www.sau.com.au/forums/topic/376508-go-karts-sydney/
Fastlane Karting in Minto is pretty good value and a fun track. Hard to master the track aswell and the karts are a bit shit but good enough to get sideways.
They also do events on certains days that are good value...always wanted to go but work or uni gets in the way.
Also compared to Eastern Creek, i think i was in the 2nd fastest karts at eastern when i went, Fastlane shits all over eastern creek in terms of price and karts but maybe not track.
https://www.sau.com.au/forums/topic/376508-go-karts-sydney/#findComment-6005418
Minto has brand-new karts 2-3montha old which has made thier nice little track much more fun
eastern creek has the biggest track and plenty of room for building up speed and passing
Picton has a great track and good karts which is great fun to try and master there's a great hairpin right at the start of the track that could see you do well or not then 2nd last corner could see you bog or kick arse as it's all up hill from there.
And if you like the sensation of sliding woodville indoor karts is some insane sliding fun. You don't lose speed and you can bum steer amd literally take corners at 90 degrees.
Picton is my pic of the bunch.
Have to check out windsor.
https://www.sau.com.au/forums/topic/376508-go-karts-sydney/#findComment-6007187
Windsor is very technical with plenty of opportunity to crisscross
What?
Oh right... Eastern Creek is lots of fun nice open track but expensive.
Kartattak near the airport is a bit small and indoors, but still alright for a bit of a bash.
Next one to try for me will be Butterfly Farm in Windsor which, judging by youtube clips, looks like a good track
https://www.sau.com.au/forums/topic/376508-go-karts-sydney/#findComment-6007538
Picton look the best overall, in terms of price karts and track
got 2 questions
question about picton, Who much HP are the karts, it says 211cc 4 Stroke but id like to know HP if anyone knows
question about Eastern Creek, Which track do they use the most???
heres a link to all the configurations at EC - http://www.easterncreekkarts.com.au/hire-circuit-map.php
Minto and Windsor only use 6hp karts, so thats why i probs wont go there.
https://www.sau.com.au/forums/topic/376508-go-karts-sydney/#findComment-6007999
Picton is no good if you're a fellow that is on the heavier side... The main straight is uphill.
And don't know about HP, they all seem to vary from each other so greatly (All hire Karts do) that there is no point asking!
https://www.sau.com.au/forums/topic/376508-go-karts-sydney/#findComment-6008178
Haha that is very true. Even racing karts, between rebuilds of engines many many tenths can be lost.
https://www.sau.com.au/forums/topic/376508-go-karts-sydney/#findComment-6008210
Went to picton today and it was awsome.
so true, found it very hard to master that hairpin, did a best of 42:38. Great track and good karts
im a light guy and on the corner right before the straight, as long as i got on the inside lane with some good speed i would fly past the heavier guys up the straight, like a baws.
https://www.sau.com.au/forums/topic/376508-go-karts-sydney/#findComment-6010061
You will do that even without taking the last corner that quick...
I'm a heavier guy and I think I was running 42.2 around there last time I went (About 8 weeks back now)
It's a good fun track, but you need a proper kart to have some real fun on it.
https://www.sau.com.au/forums/topic/376508-go-karts-sydney/#findComment-6010137
