ae101 / ae111 levin.. quad throttle bodies + 8800rpm = symphony
my old ae101 - miss it badly. handled like it was on rails, 500+km to a tank on hard driving, parts are fairly cheap, easy to work on.
comes with the 4a-ge?
can they be sourced locally? aren't they like imports?
  • Replies 204
http://perth.gumtree.com.au/c-Cars-Vehicles-Motorbikes-Parts-cars-Toyota-Supra-3L-Turbo-Manual-W0QQAdIdZ309747483
Gratuitous plug, I am selling it, I am in WA, it does need rego but it sort of fits your criteria and its cheap.
There are a stack of cheap fun cars on gumtree.
I even saw a RB30'd KE70 unfinished project.....
you could pick up an old mitsubishi cordia with a 4g63 for under 5k if you can find one, or a galant with 4g63 ( the turbo ones) , cordia is old put if you picked one up for say 1500 you could boost it up or bolt a garrett and an intercooler on..
or pick up the old celica supra 84 model for 3k and maybe swap the engine for a v8 or turbo supra motor for a few thousand more, even a vl turbo engine slotted in would go hard
haha are you from thommo?
lol yeh around that area. i used to have a canary yellow bt1 mockup vn 6. locker. vl calais .. locker
this thread asks for "FUN car under 5k"
and people saying civic? wtf that isnt fun
il show you fun thommo factories haha
lol f**k off, im from lalor.
are GT starlets under 5k?
what about SR-V pulsars (the ones with the SR16 engine)?
SSS pulsars are already at the minimum 5k in perth :(
tons of normal starlets but no GT's for sale either
http://perth.gumtree.com.au/c-Cars-Vehicles-Motorbikes-Parts-cars-Honda-Civic-for-sale-W0QQAdIdZ312470731
that looks really nice to me .. although if i was to buy something like a civic id prefer an older/cheaper one ..
http://perth.gumtree.com.au/c-Cars-Vehicles-Motorbikes-Parts-cars-Honda-Civic-VTI-94-W0QQAdIdZ310806290 like this!
theres also this e30 .. looks to be in great condition
http://perth.gumtree.com.au/c-Cars-Vehicles-Motorbikes-Parts-cars-1986-Bmw-325i-E30-W0QQAdIdZ289164601
wouldn't it become expensive to keep sending it to a bmw specialist for servicing etc though?
i dont know much about bmw's but ive been told they get expensive to maintain ..
no idea but i thought BMWs needed more $$ for normal maintenance ...
im just doing some research on other peoples 120Y/Ke rolla projects and see how much theyve costed them, if it doesnt seem to expensive im really quite keen on the 120Y, i dont mind waiting around till a good one pops up
if not im probably sold on the hondas - just need to decide out of civic/prelude/integra
its usually people who have not owned beemers that say they are unreliable and are high maintenance cars. i thrashed my e30 jps for ages and nothing broke. sold mine for 3.5k with a short ratio box, lsd and reground cam.
s1 s14's are cheap nowadays as well.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
