Hi
Im no expert on boost but as far as i know if u have a turbo car, any turbo car, and u want to add boost ( which is fine within limits) shouldnt there be a few other things to do first?
My mate just bought a stock Ford XR6 Turbo... :( not my choice but all good) So the first mod he has done today is add boost......
Shouldnt he add an upgraded intercooler first ? as the turbo will now run harder with boost, he should replace the factory fitted cooler to a larger after market one? and shouldnt he add an upgraded exhaust to cope with extra backpressure, and mebbie even wastegate?
Im not sure how much boost he will run, but i can see a disaster heading his way without other mods to cope. I argued he should do the other mods FIRST to which he says nah all good, so i advised him to run under 10PSI if he isnt doing any other mods.
Any advice is appeciated, thanx u.
Edited by nathanau
Xr6 boost is controlled by the ecu. Im curious to see what happens.
Best to just get a tune.
Hmmms well im curious to see what happens too lolz i can just sense something melting or blowing up..... My mate has Zero knowledge about cars other than to change gears etc.... He wouldnt even know how to operate boost or what PSI is..... he said one of his mates is installing the boost .. some guy who just runs rats on the road...
My mate is into his xr6 turbo first thing first is get intercooler piping done. The stock plasticpiping is designed to burst at anything over stock then tell him to get a flash tune. Stock intercooler is fine for up to 400rwkw
a better cooler and exhaust would have given him more power on the stock boost than turning the boost up a few psi with nothing else done to the car.
Hi dude, yer that sounds like a plan. But he is just running after market boost now, and im guessing its going to be 10 ( knowing his mate) or over 10psi..., without any other mod... and no tune, nothing else.
Edited by nathanau
It will have a fit and the car with do stupid shit. The xr6t is unable to have things like this done because the ECU protects everything.
In other words, only way to raise boost is with an edit.
Looks like he's going to learn the hard way. Tell him to put a big vent to atmosphere bov on there too.
Do not boost using a boost controller will cause problems like leaning out which can cause his motor to blow
heya , yer thats kinda what i figured, i already told him to expect this, but i also wasnt 100% sure, but its gotta be logical, for every extra bit of output you add, there has to be an upgrade to cope. Ill find out tomoz how it all went, i know they did the work this afternoon.... I wonder how then they got around the ECU....
I told him to add that but he was like " nah i dont need that" lolzzz i was like Grrrrr! But im not an expert so i figured id ask more knowledgeable ppls here :)
You can't get around ecu tried it on mates xr6 tell him best bet is go see a tuner that deals with xr6t's my mate got a stage 1 kit done for 2k including tuning which was bigger injectors metal piping and flash tune gained him 80rwkw
Thanx dude, shall be passing all these comments onto him. I told him to at least join some forums first and as some questions and read. but nope I cant tell him .
anyone know where i can buy more boost so i can install some on my car? cant seam to find it on just jap....
Yawns.... more for his benefit than mine... but i did make a post re Turbo Timers not been safe for car theft... u can comment on that :)
http://www.skylinesaustralia.com/forums/topic/376892-trubo-timers-not-safe-for-theft-of-car/
Edited by nathanau
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
