Hi Guys,
just wondering how many of you have replaced the engine fan with a Thermo model instead. For a daily driver, wife to work and back... Me having some fun on weekends..
Did a search for Options and this looks like the go..... Any preferences opinion on this?
And if so ball park cost.....:thanks:
The clutch fan is almost guaranteed never to overheat the car. There is drag on the engine but it is fairly idiot proof compared to some of the issues that can come with thermofans (from appropriate shrouding to decent thermostat control).
There are numerous threads in forced induction from memory on the pro's and con's.
To go against the trend a bit here I have a 16" Davies Craig & have never had overheating problems be it in heavy traffic, on the dyno, etc, etc
So many people on here (not saying the guys above) make it sound like it can't be done without issues but like anything, if done properly, it can...
I hope my post didn't come across like it can't be done, it can. However you want to go in with your eyes open as there are potential issues.
I would love to remove the clutch fan for a reliable thermo but last time I looked (admittedly a while ago) I decided it would be cheaper and easier to go with another stock clutch fan.
What thermostat are you using wlspn?
Im using this to control my thermofans.
http://www.spalusa.com/store/Main.aspx?p=itemdetail&item=FAN-PWM-V3
On my 180sx I used ba falcon twin fans controlled with a greedy unit. It took temp reading from the factory ECU sensor. It controlled both low and high speeds of the fans and when aircon switched on. It lasted on there about 2 weeks before I replaced it with the clutch fan.
The temps always fluctuated within 10 deg where as the clutch fan keeps them within 3. The factory clutch fan is a heap more consistent and easier.
I don't think there's a Thermo fan on the market that can push the amount of airflow a clutch fan is capable of pushing.
I've used thermo setups before, and eventually gone back to the old clutch style fan. Simple and effective.
Yep, exactly what I thought easy and simple.
My 2009 ford ranger still uses it so... Why not.
@ 165 for a new one why not? Anyone had one of these go die?
Would love to know....!!!
No, as I said in my post, that wasn't aimed at anyone in this thread or anyone in particular, have just seen guys on here stating that a thermo will always cause overheating, etc & it's stupid to use one.
Just wanted OP to realise it can be done but as you say there are things that can go wrong or be done wrong...
When I first fitted the thermo it was due to cooler piping & I preferred the idea of that rather than removing the standard shroud or trimming blades as some people do.
My cooler setup has now changed & I could run the clutch fan again but currently have no reason to as temps are very steady under all conditions...
Nothing wrong with the clutch fan. It does its job superbly & is basically idiot-proof.
Fan is controlled by my Haltech (through standard temp sensor) with an over-ride switch
Edited by wlspn
