New article in autospeed about my r32 GTR with rb30dett build:
http://www.autospeed.com.au/cms/A_112538/article.html
This is part II of the build - there is a link to part one (the rb26 bolt-on build) in the first para of the article.
Let me know what you think!
Nice reads. I had read your revisited one a while back.
I am somewhat curious of the power outputs... Your 2530 adventure saw you make stock like numbers..
And now your RB30 adventure seems to have panned out again to fairly entry level numbers.
By no way am I knocking you or your build, I admire the effort and especially your articles, yet what of the results in your eyes?
Um, 279 kilowatts at all four wheels on an r32 GTR is "stock-like" numbers?
Don't know where to begin with that one. As for 383 kw at the treads being entry level...
Edited by dorifticon
I did say dont take offense..
280 at all 4 is definitely doable for the stock turbos. A full exhaust and a tune will net that without too much drama.
I call 380 entry level when comparing it to 26s, I guess I felt a cammed 30 would fairy easily exceed 400 with these turbos. Its certainly not a small number but is more or less what you see from factory motors.
Have you ever run it on a different dyno?
Welll written Andrew; I agree with Steve-O...a must read for anyone contemplating a 30 swap.
I knew you were in trouble when i saw the pic of the HKS triple plate "quite abrupt engagement" lol. I just got rid of my HKS twin for a ORC.
esp is one of the slightly higher reading dynos in town if you were thinking its a low reader?
MM no I wont go there. Interesting info tho..
Yeah my car makes a bit more power than it should on ESP's dyno (see my sig, that should be more around the 18psi figure for the turbo I'd think)
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
