  • Replies 122
I tried it but it didn't really do anything as the lean popping is mainly when holding about 2k+rpm on idle. Will it count if I get someone in the car to hold rpm while I fill it? Pics on my phone of the pipe on the car, will upload tonight when I finish work, can't upload pictures from the phone.
In regards to my fuel setup though everything is brand new except lines and regulator. Nismo injectors, Bosch pump, ryco filter..
I think its because of your pringles designed intake pipe you're popping, as we all know with pringles, 'once u pop, u cant stop'! On a lighter note, i know how frustrating ur problem is, hope u find a solution soon, sounds like an air related issue, did u get jez to look it up in the wknd?
The point he is getting at is the fuel being cold, as long as you don't leave it idling for 10 hours after filling it it will answer his question.
grab a datalogit, and send me your ecu file in a PM.
Cheers
Shall send you a pm shortly. Just got home and it decided to lean pop on idle now and constantly too. I might have to give that test another go. But its strange, on hotter days I've given the car harder times and idle is fine...
where are the pictures of the intake pipe and how it is mounted int he car? why should i bother trying to help you when you can't even bother to upload simple pictures?
:rant:
:rant:
Because your a nice guy who wants to see skid videos :)
When my car is finally sorted I promise to upload skid videos for all those that helped(On a private road/pad of course, when i turned 30 my wife said i had to grow up)
:rant:
I attached them to that pm I sent you but after checking it nowi see that didn't happen. Ill post then again here and in the pm. Your help is always appreciated man, sorry about that man.
I tried PMing them again. Realized they are close to 2MB each. Got my computer now so lets do it from here! Pictures are pretty rough, I'll be pulling it all apart tomorrow for better pics of the pipe out of the car.
Also just fitted a new fuel filter, just incase.
Can't edit the above post anymore but here are pictures of the intake pipe OFF the car. You can see the outside and the inside of the pipe. My new design pipe has another bend just at the turbo with a 2 - 3" leg which will be the mounting point for my return and breather lines. It will have 2 maybe 3 bends in it.
The black shit is that silka sikka or what ever its called, that black glue shit. We put it over the weld bead just incase there was an air pocket somewhere.You can also see that the intake pipe is not exactly 3" on the bend. We sliced out a moon piece then bent the pipe shit and welded it up.
Hey sarge. Those welds are hectic. Ill subby all my fab work to you from now on. Make sure u save those pringles cans for me lol.
Anthony has a good point. The afm element position is fairly important.
The afm element orientation isn't an issue if the AFM is standard.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
