  • Replies 199
Love the Bentley Martin. All you need is super low sus, a set of 20's and you'll have full VIP style :thumbsup:
I now have the Nittos (70+% tread) in the boot of the Sigma, thanks again Steve (& keir - damn nice bloke too) Hopefully by COB today they'll be on the rear of the Skyline :D A quick wheel aligning sesh tomorrow and then it's off to AIR.
See you there Matt (check your PM too mate).
I'm coming out too .... but not to race this time - just to watch and get some footage of Matt doing an 11 :D .... to put the pressure on, if you don't do a big enough burnout before the run and subsequently have grip issues, I am taking her on the track for the next run to show you how it's done :thumbsup:
Nothing ever goes according to plan...
I need my guards rolled ASAP! The Nittos are on but unless I run huge neg camber they rub on the the guard lip like buggery :) The left rear doesn't rub but the right has already done some minor damage :D It's only cosmetic thankfully.
So, can anyone point me in the direction of a place/person that does QUALITY guard lipping/rolling? Preferably in the Nth East area, or even better someone that does mobile guard rolling.
I might post this up as a seperate thread, as I need it done ASAP if I'm to run the upcoming AIR meet!
city discount tyres ridgehaven can do it, and a few other tyre places, do you only need the lip rolled? as they wont do anymore. i needed mine pumped out 2cms or so and no one would even try it, so i had to get a pannel place to do it
Thanks for the help fellas :cheers:
Late breaking news - I've got a guy that does mobile guard rolling ("Slammed" is the business name) coming around tomorrow arvo to do them. He uses a heat gun and the usual hub bolt-on rolling tool. After he's done it's straight up the road for a quick alignment and that "should" be all that's needed, fingers crossed!
Clint, how wide have you gone in both rim and tyre? Is the R32 rear guard less accomodating than the R33? I sure hope I can get away with just a lip and camber job!? PLEASE!
You wanna run 9's!?!? No wonder you need big arse pumped guards, you'll need them to house the rubber needed to run a 9sec pass in RWD :cheers: Hehehe... oh, you mean 9inch wide :D
Thanks for the help fellas :P
Matt, can you let me know how good a job he does, as I need to get mine done too, and also what are his prices like?
Clint - need to catch up soon a d have a go at putting in those rear cradle bushes, the ass end on my car is all over the place!!
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
