This was delivered earlier today............
In other news....
Going to spruce up the rims as best I can and then put all four on the car to narrow down what tyre specs I want to run.
Leaning towards 245s 40/45 18 (common size and therefore cheaper) - though I would like to run 255s.
Also debating what tyres to run.....tossing up between Ku31s, Sumitomo z111s and Toyo T1 sport
Awesome choice of wheels Jez. Got a photo with them on? I reckon it will transform the look of your car totally and the dish will suit the black-on-black theme you've got going...
Thanks - I do :wub: them.....
Will post pics asap.
Black centres... whats the sizing?
OH MAN...Don't start that again :domokun:
(I can hear Jonno screaming "all black" and my brain screaming "gold with silver lip" and you going "black centres please - thanks" - noooooooo its in my head !!!)
18x9 +35
Don't forget to look at the Nitto Invo Pro; killer spec for the price.
Those rims will definitely be a slick addition.
Cheers Dale...will check.
Any recommendations on where to pick up tyres from btw??
I pm'd Taleb Tyres on here but no reply yet.
Anyone bought anything from Ozzytyres?? - seemingly awesome pricing.
Amazing work! I'm glad to see someone else taking the one colour look so well.
(One day I'll make everything blue!)
Thanks man........plan to still keep the silver lip though even if I do powder coat the centres.
I like blue :geek:
Damn those rims look sexy as fark!
Love how this car has come along
Thanks mate :) There was a time when I was tempted to go with your setup (black on black looks killer too).
ITS MY BIRTHDAY !! :banana:
Went for a trial fit this morning to my local tyre place to finalize sizing etc.
As of now I am going to run 235/40R18 fronts and 255/35R18 rears
Will be ordering my new tyres soon.
Also, want the car looking the way I want it now so going to run 10 or 12 mm bolt on hubcentric spacers on the fronts to get the wheels looking a tad more agressive. (provided I find some - only found 15s so far) There is no way in hell I am running slip ons - say what you may!
Will not have to change the factory bolts as the rims have space for the protrusions (yay!!)....so might end up running spacers on the back as well. (P.S. I am aware of the legal stuff).
Stay tuned.
Edited by jez NF
its looking tougher with those rims, nice work :)
I want one of those seat covers.. lol
You no get ma seat cover niggaaaa !!
Update:
Ordered these this morning....
Could not find bolt on spacers in less than 15mm so ordered a set (see below)
where I get the two 15mm bolt ons that I need and a few extras to play with when "posing" !! :cool:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
