Thanks for the heads up Dale.....btw - what are the disadvantages of going with a 20mm on the rears?? Is there a massive difference in performance etc. Will it even be noticeable? They have access to the fronts..waiting on the rears (want 22mm).
Bored of waiting for the sway bar install and the wing is still work in progress so took the car out for a drive this evening.....few pictures :)
That ass :wub:
b1ab3db8-0490-4458-85ba-979698abb61a_zps
Kicking myself for not taking my camera...was such a nice evening !!
77c1a4fe-b4d8-4e0a-862f-d1e44c577ee9_zps
Don't quote me on this, I'm no suspension guru but from what I remember a big front sway bar and stock/small rear will increase under steer. So make sure you go a a decent size rear......no one likes under steer.
Yeah thats for sure Justin....I have read up a fair bit and for what I gather the stock fronts are 18mm so if you go a 24mm solid or 27mm hollow front they are more than sufficient and rears should be 20 solid at the very least to make any significant difference - though I have ordered 22mm solid anyways.
No clue when they will get here though :/ bummer
The supply issues Whiteline have been encountering are very close to being over; if you like; PM and I can give you some background on why it is happening.
Swaybars are arriving early next week - car booked in for Wednesday morning (YAY!!)
Might be getting my guards rolled today (if all goes well) or possibly next week as well...so can get the rears out a bit more and possibly lower the car a tad.
Gave the rear guards some good old fashioned "hammering" this afternoon....works a treat if you grind little cuts strategically along the "metal lip" bit which basically allow it to bend backwards in sections rather than attacking the whole piece as one - (as Brad and I found out halfway through)....should not chew up the tyres now.
df14db85-83aa-4884-a3dc-6531e822ecb2_zps
There was a little bit of paint flaking from the undersides despite our best efforts with the heat gun. You could not really see it unless you squatted on all fours - but I am crazy....so a light sanding and rattle can spray job was done on the insides of the lip and the underside of the arch.
672c3e16-d133-4b46-a23e-4fda41494662_zps
Awesome idea about the slight cutting.
I tackled the whole thing at once and it was a big job that took a lot of patience.
What technique did you use?
Pushing hard against the outside and just tapped away with a hammer on the inside?
Yeah....wrapped a hard bit of metal with soft cloth and after heating the guards held the outsides with a fair bit of force and let loose with a fairly heavy hammer on the insides. We tried the left rear as one bit and boy was it a pain in the arse !! Halfway through we decided to cut sections and man did that help. The right was a breeze with this new technique and wrapped up nice and tight.
A good job overall and definitely no scrubbing etc...even when it squats while launching :woot:
Yeah had the guard roller but ended up not being used.
Had the new sway bars installed this morning.
Rocked up first thing and parked amongst some interesting company......
Up up and away.....
Wish I had one of these bad boys at home (hoist)....would make life SO much easier :/
6d9027f5-f15a-42d7-b6df-e713558674d4_zps
Out with the old..............
In with the new......
4e2a069e-ca76-4c08-824b-ad2f6cc1b782_zps
Back on solid ground and ready for a test run.....
24b5fbe8-1b2d-496d-a659-3450919150d1_zps
Verdict: Freaking awesome !! Massive difference !! Virtually no body roll and much tighter lines through twisties.
Hard on the rear and medium on the fronts is the right combination in my opinion. Glad I went with medium on the front because I can feel the slightest bit of "stiffness / harder to turn in" compared to before. I reckon the hard setting would be too much.
Small update:
Painted the spacers on the front the same colour as the hub to "disguise" them as far as possible.
On another note....how hard is it to flare the lip / edge of the rear arch??
Something like this.....
It will take a lot of patience skill and it'll more than likely need filler and paint after unless you really know what your doing. In fact allow for paint no matter how good you are lol.
Hahaaa...yeah Brodie....will work on that hurdle when I get to it....but it looks real nice so knowing me that will be my next project.
Picture of how the spacers on the fronts look now........
Spent this evening down at the workshop getting the wing project moving...taking forever !!
BUT PROGRESS IS BEING MADE................
Ensuring that it is well reinforced and that the light still works so after a few teething issues it is now well on track....
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
