  • Replies 59
I have a R33 GTSt log booked as a sports sedan, I would not be very competitive but it is its only home. This car would suit the MRA series nicely I have done one regularity event with them and it was a great day. I have done a few of the SSCC rounds and a few SAU days and a go at superlap. I have had a ball it the boat but it has been costly, if I can give you some advice choose a car that is affordable to race unless for have some healthy financial backing. A N/A Silvia would be a great place to start or a bog stock R32 or S13 turbo this way you can spend less on tyres, brakes and fuel and more money on entry fees.
Good luck and have fun.
Cheers Ryan.
But "affordable" is very relative when you are talking about door to door racing. It's brilliant fun but like most things in life that makes it very expensive.
Club racing (non CAMS) will probably cost $5-20k for the car + $500-1000 per round in tyres, fuel, travel etc.
CAMS state racing $20-50k for a good car (or 200k+ in sports sedans) +1000-5000 per round (depends how many sets of brand new tyres you can afford per race). I run at this level
National race series $50-$200k to buy a car, and say 20-50k a year to run considering travel, crew, tyres/brakes/oil/fuel, maintenance and repairs.
Supercars, Porsche cup or Superlap $200-500k for the car and 100k+ per year to run.
Tarmac rallies 50-500k for a competitive car + 20-100k for a full year (3-4 rallies).
So...I guess the main thing is to be realistic about where you can fit in. If it is under the club racing budget stick to track days and enjoy them....if you can't afford track days enjoy motorkhanas at $50 a pop.
Thanks for the heads up. Some great advice hear guys. doesnt make it sound quite as intimidating to get into.
Hey everyone is friendly at the race track :D
Unless you finish in front of me....then its on, f**ker :mad:
What about finishing the March in March....finishing the Superlap nugget by Super Lap 2011....
But then I would have to mention building my 33 for circuit stuff...or lack there of building it then selling it
hahaha your memory is way too good.....but let's face it, you've got to shoot for the stars, even if you only make it to the moon, at least you got somewhere :D Those projects are all still live but behind the house....
hahah the only way you will get to the moon is by riding bits of your main bearings as they fly at a bazillion mph out of your crank case :P
oh btw...i will galdly take the SL nugget off your hands...will swap you for a super quick Cordia build to dominate Endurance racing*
*may or may not be true
Speaking of r32's
I'm building an r32 currently for John bostons trackschool business.
He bought the rolling shell for $500
Ford I6 4.0L engine conversion $3000
Basic Cage $2000
Coilovers $1000
Seat/harness $800
Wheels/tires $1800
The rest is all just little bits of labour to neaten the car up.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
