saw it at autosalon yesterday, was a series 2 r33 with the plates PUNKD(i think there is meant to b a pun in there), and inside the engine bay there was a Phat Eaton(i think) positive displacement supercharger, no turbo to b found. my guess is it was originally NA and he made the switch to blow it, pretty unique i think.
https://www.sau.com.au/forums/topic/37763-super-charged-r33/
it was messed up graphically... it had robotech side graphics and a big arse transformers autobots sign on the front... and also the word transformer somthing on the side next to veritech fighter off robotech... very bad mistake if you're a robotech or transformer fan (both of which I am).
The supercharger amazed the f**k thru me, but I could never find the owner around the car to drill him for questions... I've got pics of that engine setup from every angle so I should be able to find out who made it (and possibly get a replica) :)
https://www.sau.com.au/forums/topic/37763-super-charged-r33/#findComment-760230
Eaton supercharger. Maybe ask an eaton s/c dealer in victoria.
I was almost hoping there was a turbo underneath the manifod, but sadly none, just pipe leading straight to exhaust :)
I'd imagine it should be near to stock RB25DET output power with fatter down low torque curve, as most s/c are low boost induction around 6-7psi and works well at lower rev range.
I suppose ECU should have been changed as well. I was here today and seen no one standing by to be asked some questions too. Oh well... leave us wondering.....
https://www.sau.com.au/forums/topic/37763-super-charged-r33/#findComment-760250
Then could it be an RB25DET with turbo replaced with the super charger. Considering both stock boost and supercharger is the same, engine and ecu could cope with it. The only difference is that you get instant boost right from idle. No lag.
https://www.sau.com.au/forums/topic/37763-super-charged-r33/#findComment-760336
well theoretically a Supercharger is a non invasive upgrade, ie it does not require that you modify any internals, or exhaust system. you don't neeed new headers.
So realistically for an N/A its pretty cheap alternative.
https://www.sau.com.au/forums/topic/37763-super-charged-r33/#findComment-782431
Ive seen him run at sat nigh church. Nothing special, keeps up with most other cars it ran.
and yes wtf is with mixing the robotech veritech with fuggin autobot tranformer emblem? oooh he should be shot (im a robotech transformer fan of ye OLde)
https://www.sau.com.au/forums/topic/37763-super-charged-r33/#findComment-783803
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
