  • Replies 99
Thanks for that Sprinta, I still can't tell the difference, so if it's good enough to fool me, hopefully it's good enuogh to fool most people (I think they just look better anyway).
Did you have much problem putting the povo pack lights in?
actually thats quite contradicting..
look at my povo pack lights
btw i dont have the gtr grill backets on the lights either, has custom backet things made up so the grill fits
Also has anyone replaced their GTR side indicators (all orange) with the GTS ones (Clear with just a small orange indicator) before? The guy at just jap said they won't fit because of the guard.  anyone tried?
The GTS ones won't fit - GTR ones are wider to fit the guards :rant:
Arrgh! still don't know.
I think a good way to tell would be to weigh them - N1s should be lighter - otherwise why change them??
You drive an R32, right? It should be pretty obvious: the stockers are shockingly bad at like, you know, lighting the road :rant: IIRC the N1s have better illumination.
LW.
mine didnt have that bracket it had some little metal bits with the cutouts for a bolt to hold the grill on on each corner. I just changed to projector lights today. Looking at em now the standard type lights look better on gtr's in my opinion.. still looks ok but
I got the clear indicators on my car and I was pretty sure they are the pov pack GTS4 ones.. but... they light the road up really well?
http://www.users.on.net/~ajh/My%20Car/IMG_..._19255small.JPG
They are the standard "pov pack" indicators, and I would guess the standard GTS/4/t lights (bit hard to tell from that distance/angle).
Do you mean they light up the road well on high beam, or low beam?
LW.
since thread is entitled questions
thought I'd ask here
Can someone explain how to adjust the 32GTR headlights up! mine seem to aim low, and the bulbs are sitting ok in the sockets, someone said look for 2 screws in the back ot it. found them
but when I screwed them either way they didn't do jack
pics would be great
cheers
mark
Ronin,
That's cool, I was going to put the Povo GTS-T lights on the weekend but ran out of time.
Did it take long to get the bracket from nissan? and how much did it cost?
thanks
Michael
Hey michael, haven't actually got any from Nissan (found these pics on the yahoo japan auctions), but i would expect that if they are ex-japan, they'll take 2 weeks.
  • 3 weeks later...
Does anyone know what globes each different type take. I have 2 of the projector lights (one of which has been replaced because the glass was cracking), and the low beams use different globes (1 is a H3 and the other is a H1). Which is a better globe? I'm going to guess that the H3's are better being that they are 25 bux each to replace with a run-of-the-mill globe :confused:
Thanks,
Michael
Thanks,
Michael
Gday mate,
You'll have to use the same ones as the assembly was designed for because the focus point on the globes has to line up.
If they don't you get a very very very dim projection from your headlight(s).
H1 and H3 are definately not interchangable (I've tried, even when you make em fit the focus point is out of whack).
Gday mate,
Yeah, it wasn't until after i got the replacement that i realised that the new one was H3. I pulled apart some of the assembly in an effort to swap both of them to H1, (the broken one i had was H1), but they are very different.
Basically what i want to know is which type of headlights came out with which globes so i can find a suitable replacement and match them up :P
What type of globes does everyone have, and which style headlights have you got on your 32?
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
