Hi guys n girls
My girlfriend has a m35 coming up to it's 100,000 km service,
What does it consist of and also who in Adelaide would it be good to take too??
Second question is,
When putting the car in reverse the car seems to shutter , it get worse when u turn while reversing , and also happens when in drive and slow speed but will go away once on load( 50kmh +)
Feels like the shuttering comes from
The rear but not 100%
Has anyone heard of this or had it, or know what it could be?
Thanks in advance :)
https://www.sau.com.au/forums/topic/378262-few-m35-questions/
100K service is nothing major on the VQ25DET motor as it has a timing chain that does not need replacing.
Depending what has been done since you owned it the things you could look at are.
Oil & Filter change
Radiator fluid
Gearbox fluid (but not essential)
Diff fluids (but not essential)
Check brake pads & fluid
Grease hinges
The shudder in reverse is common as you have to remember you have a 4WD system and they don't like being put on full lock in reverse. This can be made worse by having the "Syncro" button depressed.
Maybe the gearbox fluid change would be good to do.
Cheers
Andy
Awesome thanks guys,
Yeah there's a fwd light on the dash altho, it has never come on , but when we first looked at the car and test drive it, it was on, hmmm
What does the light mean???
If the AWD light is light on the dash it means the ATTESSA AWD system is faulty.
I get that intermittently...but I wonder if its because my ECU was falling out >_<
Will check that tomorrow and go from there , really hope there's nothing wrong with it as I know they are very costly
Not necessarily... could be anything from needing to be bled to the relay being faulty.
Why not bleed the system and go from there?
Yeah that's my plan, see if this lights on there, if not see if there's a globe and findthe last owner for a chat , then bleed it ,
Is this the correct way of bleeding it ?
http://www.skylinesa...leeding-how-to/
More or less, the white plug that you need to unplug is located on the ODB2 cable under the drivers side dash, you should see a small hatch with the plug attached, pull the cable through and you will see a plug, just unplug it and turn the car on to reds and you will hear the pump start to turn. Make sure you open the bleed nipple on the back of the transfer case a fair bit to get the fluid moving. IT WILL MAKE A MESS so be prepared as it will go through a fair bit. Having 3 people there will help the job along, one person at the nipple, one at the rear topping up fluid and the other turning the car on and off. I use Matic D in the atessa.
Also the nipple at the motor end seems more like a drain nipple as it is gravity only and does not require the pump to operate in order for fluid to come out.
Mike.
the nipple at the transfer case is under pressure when the pump is running. even when the pump is stopped.
hydraulic systems push bubbles to the furthest point (generally), so the bleed nipple at the motor end is the one you probably need to bleed
Ok just had a little look at the car,
The 4wd / awd light does not come on when ignition is switched on, Does anyones????
I found were to fill up with fluid and it is above the Max line :)
I then checked the plug under the dash and check to see if It was connected , can hear the pump working :)
Will attempt bleeding the system on weekend and see if that makes any difference ,
Pretty sure mine lights up when the ignition is in the on position.
Ours doesn't line up when the sync switch is on snow or sync,
Are we talking about the little pic off the 4 wheels or the word "4wd"?
Yes, although I may be mistaken with what I said before. :blush:
Will test it out tonight after work.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
