This is a stupid question, but here it goes:
Do people still paint the outside of their blocks with engine enamel when they get them back from the machinist after it has been acid dipped and stuff?
My dad will be helping me to rebuild my engine (he has built a lot of them, although no RB's) and is saying that i need to paint it to stop it oxidizing and looking like crap after I clean it and put it all back together, but I like the look of bare cast iron :P
If so what colour do people mostly use?
..... Thanks :whistling:
https://www.sau.com.au/forums/topic/378570-a-stupid-question/
It's not a stupid question if you don't know the answer. The answer is black for its heat retarding properties. The opposite of this would be to chrome it which would raise temps significantly. I saw a ten degree celsius difference in operating temp on a 186hp (that's the engine name not the power) motor just by swapping a red rocker cover for a chrome one and vice versa.
Early nissan blocks were painted blue in the L series days.
All RBs were black out of the factory.
This is what gave the RB30 its famous "Nissan black motor" name amongst the Holden people back in the day.
Several coats of high temp engine enamel will be good.
Yes they were occasionally referred to as such. In the Holden tradition of grey, red & blue motors which were painted, um, grey, red & blue.
Paint the thing whatever colour you like. The advantages of black are that it wont change colour when it gets hot & wont show oil/dirt/other crap so much. The advantage of hot pink is, in the main, that it matches your handbag. Mine does anyway.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
