does anyone know where I can get my hands on, or get my air intake re-done with lots of shiny piping and stuff?
Sure, find bright shiney stuff on ebay then take it to any shop. Else go to a place like Trojan who might have some gear lying around.
Me, I prefer to get something that would help the performance over just looking bling.
If you want competition level bling, not sure there is a place in Canberra.
https://www.sau.com.au/forums/topic/378746-cold-air/#findComment-6039724
A non turbo skyline wanting some upgrades with a bit of wow factor....
Short of bolting on a turbo, I can't think of much that would help. Sure an after market computer and exhust would help a little bit, but it would only be a very little and at big cost. It is a lot like the guys with an Falcon xr6 who want more power, new computer and new exhust from the headers back will get you like an extra 20kw and a "modified" 180rwkw car after a $3000 bill. Or just sell the N/A buy the turbo for the $3000 difference and get a "stock" 210rwkw.
It sounds harsh but don't waste time and money on a car that is never going to have the performance of a normal next level up car. Look at what power you want to be making (or other aim) without rebuilding the entire engine GTS (200kw?) < GTS-T (250kw)< GTR (300kw). Make a choice on what your aims are and purchase for that aim.
As you said on your first post, and being as your car is a N/A, making the car look nice at a reasonable price is probably all you can do. I.e go ahead and add some not over-the-top bling. Then save up for a car that has real performance. GTS-T if you are on a budget, GTR is you have an additional $10K after the purchase price to maintain it.
https://www.sau.com.au/forums/topic/378746-cold-air/#findComment-6041840
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
