Item 1:
Kakimoto Regu 06 (suit r32 gtst / gtr) would fit S13 too.
3" SS dump pipe w. flex joint
Highflow Catco Cat
Price: $600 package, posted within Australia. !!!!
Condition: Very good, apart from usual dings / scratches (see pics), comes heat wrapped in sections.
More info:
The Kakimoto Regu 06&R cat back exhaust system is designed for improved street response whilst keeping within the JASMA 92db noise limitation for street use.
  • Designed for minimum bends for optimal exhaust flow
  • Stainless Steel construction
  • Titanium like tip look using special coating
  • Improved vehicle sound but not excessively noisy.
Pictures: Exhaust has been in storage, excuse the dust/dirt.
Item 2: UAS style (possibly Silkroad) R32 gtst/gtr upper camber arms
Price: $180.00 + post (estimated >/=$20.00)
Condition: Good, were modified for longer LCA, can revert to standard by cutting washer slot (see pic)
More info:
They are for sure the best type out there, no play, reliable and last forever.
Pictures:
Item 3: R33 / Rb25 Xmember
Price: $50 + post (estimated >/=$20)
Condition: Good, can relocate rack mounts 20mm forwards for extra $120.00
More info:
Stock standard Issue
Pictures:
Item 4: Custom made SS lobster back intake w. Apexi pod and silicone joiners
Price: $100.00 + post (estimated $15+)
Condition: Good
More info:
mmmm lobster back
Pictures:
Item 5: Rb25 Power steering pump w. bracket and custom reservoir
Price: $80.00 + post (estimated $15)
Condition: Good, pump works fine, cleans up engine bay allot
More info:
Stock standard RB25 PS pump
Pictures:
Item 6: R33 Clutch Master / Slave w. Braided Line
Price: $180.00 + post (estimated $15.00)
Condition: Great
More info:
$100.00 worth of braided line
Pictures:
Item 7: R32 Rear Lower Quarter trims
Price: $80.00 + post (>$20.00)
Condition: Great
More info:
In storage so excuse dirt / dust
Pictures:
https://www.sau.com.au/forums/topic/378780-kakimoto-rb25-r32-33-gtstgtr/
hey has your cat got the stock flanges for a 34???? i think there the same part for the two models
will you seperate it?
also will your pod fit on a 34 gtt??
Hi mate, quick Q; have you got the hose lines on the PS pump blocked off? I'm looking at replacing mine, but not sure when I'd get around to putting it in... had a bad experience before with a aircon compressor that had been left open (no tape on the fluid ports etc) and had seized.
If it's all good to go then I'll take it orright :P
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
