  • Replies 187
I like the last pic as well jay.. Love your perspective of the pics you capture.
ISO6400, No noise reduction.
It looks like an image of a scale model or diorama. Stood out to me instantly. Was that the intention? Long time lurker.
Sounds like you are thinking of "tilt shift photography"
*does a quick google*
http://www.smashingmagazine.com/2008/11/16/beautiful-examples-of-tilt-shift-photography/
That was the first link on Google - Haven't had a look at the photos yet but should have some good examples.
Thanks for the kind words Richie. Hopefully get a blog post up soon with all the photos from the wedding.
Nick - The photo was taken from a tilt-shift lens (45mm canon tilt shift). Purpose of the photo - none really hahah. Well just testing out the tiltshift lens as I have never used it before.
i like the shot of the pelican in flight.
just dont show any professional bird shooters, they will have a cry that its a 'butt' shot :P
(i learnt that the hard way, haha)
your beaches look a lot more interesting then our beaches. love the old jetty!
Edited by Jay019
butt shot hahaha.. Where was it taken matt? Nice set of pics.
nah didnt borrow his.. my 2nd shooter accidentally left it in my car after a shoot. So decided to take as many pics with it as possible before I gave it back to him.
Found my old 2gb memory cards.. Forgot I still had pics on there.
u sneaky f**k! i don't even remember you taking that!
Matt - how can you not remember him taking that pic. Your smiling at the camera!!!!
bad memory i guess. probably because i'm retarded.
LOL, you're a ruh-tard, Matt! :P I'm pretty sure I showed you that photo straight after I took it, too. Was just after I'd bought the G12.
I'm really happy with that purchase, BTW - it's proving to be an awesome little camera! I love having a smaller camera with most of the functions of a DSLR, so I can still play with/learn how settings work without having to carry the 60D and lenses around constantly.
Lol i was about to say no beaches in Penrith :P
Jay - Love that shot. Where is more buildings in adelaide? I think you've explored them all!
Sidd - Killing it as usal.
Nick - FCUKING LOL. Matt should use that for his Pedo pete profile. Fcuking creep.
Wilorichie - Nice shots!
Oh and a shot from me. Re-edited from ADGP.
I lost my bike messenger job so dont head into the city at all any more. It's over an hour away (3 if i ride, lol)
but... applied for a commercial cleaning position with a company that specializes in working at heights.
if all goes well i'll have access to some crazy views in future and if things go to plan i'll be able to look into specializing in photography at heights.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
