give me some feed back on this
37 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
it looks good mate :)
ive been thinking of getting a bonnet like that for my 34 with a new front bumper ... mine are both all stone chipped and kinda need a new front bumper anyway its sagging something special
i like the one without the line in the middle though if you get what i mean..
more of the East Bear one
Yeh does look good mate, well done with the mods :)
One thing to note with vented bonnets, there is a lot of science to it. What can happen with cheap bonnets or ones that aren't properly engineered is they create a low pressure zone across the top of the engine bay, which means the air will be sucked up over the intercooler and radiator instead of through it, causing cooling issues.
Also another thing, you won't get away with the "it's stock officer" line. The bonnet is a structural part of the car, modifying it as you have done modifies the structural integrity of the whole car. Meaning it is definitely sticker worthy.
Just a heads up.
Just a heads up.
holy sh** i didnt know that
  • 1 month later...
Correct!
This is why the Nismo R-Tune bonnet has a Z-Tune tube which links the bonnet with the airbox.
I didn't know this, mmmmmmm
Would I be correct in assuming that haveing a full width radiator air guide in place would offset the negative air charge?
As in forcing the air down through the IC and rad the the bonnet will "vent" the heat as one would assume it's designed for??
In God_speed's Nur Dave, he has
* R Tune bonnet (genuine) but with Z-tune tube out.
* ARC airbox (which won't accept the Z-tune tube)
* Full length air guide
> temperatures at speed are at least 4 degrees less than usual despite the ARC box being notorious for trapping heat
Wow... If that's a stock bonnet underneath and you just fibreglassed it over the top, that looks pretty impressive.
Yes my friend it is the stock one . LONG time to do it right tho
Edited by joker's r34
Just a heads up.
Looks cool, a little too "Big" for me, but still cool. Also, This ^. Definitely yellow worthy.
Does the opening make rain drain into the engine bay?
Nice work!
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
