So the Jew in me wants a cheap good turbo.
Orginally was looking at the Kando Turbos, but they seem to change design/specs every other week, so its hard to know exactly what will be delivered when bought.
I never relised how cheap these BW Airworks turbos were (cheaper than the Kando stuff)
Im looking at the S362 ala 83-75 for my 1JZ with the aim of 400+rwkws and a mid 10 in a full weight fat kent Snoarer (eventually)
So who has used these buggers?
Specifically the S300 series on a 2.5L six.
Cheers
Andrew
https://www.sau.com.au/forums/topic/378995-bw-airworks-turbos/
  • Replies 105
Posted Images
Pretty sure I have mentioned these before in regards to being an ideal affordable turbo when the Kandofandom was getting hysterical and it wasn't really heard. I unfortunately have no results to directly share but they are well documented on various international forums.. I would happily run one :) The only thing to bare in mind with the S300s is they are physically quite large.
haha yep....
So 88-75 is the S372?
I just realised im looking at the S360 not the 362
The S372 is a big bugger, I cbf checking but would guess the S366 to be 8875 equivalent.
The 83/75 should be Gt3582r like in performance, on an RB25 if you are looking at results typical of folks here I would look at the S256.
Why are there so many names for the damn things?
Do we need to bloody research and document every model just like we did the bloody MHI units?
S366... S300SX... What is what and what does it mean?
I remember looking at the S200SX and being fairly impressed.
The 91/79 is a huge turbo - that amount of lag isn't too surprising... considering I'd not be surprised if an 88/75 punched as hard as a T04Z.
GTScoTT - when I first became interested in these turbos they were known as Schwitzer S300s etc, it seems when they started being sold as BW turbos the name convention changed but some people (ie, Bullseye power) who sell them seem to have stuck with the old Schwitzer naming. The naming Borg Warner use is much more informative, and closer to the current Garrett convention (ie, exducer size).
Last weekend after indulging in a bit of rum we decided to pull out some of the turbos that were floating around the house (and a random Honda City turbo for styles sake), the result was a few size comparison pics which might be interesting in this thread.
The turbos in question are a Borg Warner S300SX 83/75 with .91a/r T4 twin scroll turbine housing, a Garrett GT3582R with an ATP 1.06a/r T4 twin scroll housing, and a stock Series2 R33 turbo :)
Yeah I remember them being mentioned, just never realized they were so cheap.
The big ft Snoarer has a big fat engine bay, so physical size isnt an issue...and besideds, we all know huge big turbos are cool ;)
Was looking at results on the 83-75 on 2JZ's and was really impressed. so even taking in 500cc less engine in my case it should be resonable, and very much similar to GT35Rs on RB25's
Also having seen Anna's (T04Daves gf's) car in action at wakie when it had a modified T04Z on a 25 it was a missle.
I have had a look at the S256. But if I do end up rebuilding the engine it will be a stroker 2JZ bottom end. So im thinking towards the future (as we all do)
ok guys. just ran up annas car,
9179 .91 twin entry, 6boost twin 44's
rb25, greddy plenum q45 tb 252 pon cam, type a tomie springs.splitfire coils haltech e11v2
25lb on 98 made 360rwkw. needs a cdi. could not get a smooth run out of it, had to gap plugs to 0.5mm also ignition timing not relly done yet. 10 degrees advance up top. was making roughly 10kw every 2 lbs boost.
had some major surge ramping up till i turned the gain down on the boost controller. having the run start a 3k.
all on by 4500. then it melts the tyres off...
need to heat wrap dump pipe, teflon wastgate hoses needed, and need to make a power steering belt guide for the pump pulley. any limmiter it chucks the belt off. (ross tuffbond balancer)
if i had a choice now i would be getting the 8875. but compared to the t04z the 9179 has heaps more power coming onto boost. seems more torquey
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
