  • Replies 105
Posted Images
[OFF TOPIC]
I alway liked the Soarer, and I was looking at many Soarers for sale ..
Eventually I bought a Skyline since it had more 'easy' potential for tuning.
Shame was that I wanted the V8-package but the Twin-Turbo engine.
(I saw nothing special in a big luxery cruiser with a V8)
lol...
Well in the 15months ie had the Soarer I have changed the plugs twice and made an air guide for the airbox and thats it
Yeah it looks the good, my only concern is the cut back turbine wheel compared to the 83-75, will have to try and find back to back results to see whether the extra power will overrule the extra lag lol.
the 9179 has the cut back wheel.
the 8875 has the same wheel as the 8375 but with "cupped" blades instead of straight.
  • 5 months later...
Righto thought id post a small amount of data
BW 83/75 on a twin scroll manifold
Ended up running out of fuel by maxing out the injectors and fuel pump but upgrades are on the way along with E85 :thumbsup:
Yavuz wont give me a graph untill the thing is making full power hahah
anyway engine is a forged 2.6 with tomei 260 cams
car made 375RWKW on 19psi, (will be boosted to 25psi maybe more depending on Boost vs Power) then will be tuned for response
pretty happy with the curve atm but will be intersting to see how a cam gear adjustment and e 85 effects it :rolleyes:
Edited by GTR_JOEY
Do you have a sheet?
Im very impressed by power vs boost, I thought it may have needed more than that
edit - just noticed your edit haha
Yea i was very impressed, thought it may struggle to make 400rwkw but i dont think we're goin to have any problems
...and the turbo whislte, sounds.. f**kin...awesome..
not quite T51R territory but definatly up there
not bad for a oil cooled, plain bearing turbo thats under 1000 bucks!
Nice, sounds like its on its way to being a bit of a monster - I bet it sounds awesome :) Whats the exhaust note like with the twinscroll setup?
What turbine housing are you running, and what is response like?
So 375kw was pump gas - right? If so, with 25psi and E85 this is going to be a weapon! Very cool!
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
