  • Replies 105
Posted Images
Not too bad actually, a little bit laggy but thats what you would expect from a turbo that will potentially make 450kw+
I'm also using a link g4 which makes the car very nice to drive, especially on light throttle.
Will hopefully have a dyno graph to post in the next couple of months
  • 1 month later...
EFR 8375, s300SX, s366SX the S300 FMW also looking closely at some of the precision turbos, 6266 or 6466 I think, all up in the air ATM.
Ended up ordering the S366 with 0.91 divided rear end... need to wait a while to get the 1.00 A/R but should be able to do a back to back measuring exhaust manifold back pressure!
I was so close to getting a S300SX FMW but bailed at the last minute in favour of a 6262.
Mainly because of the lack of results for the FMW and Joey's not sounding like it has the best boost response.
Should have some results in the next week or two
  • 3 months later...
  • 4 weeks later...
Did you get around to measuring this Mike ?
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
