I am getting tired of my R33's drony 3" system
I've done some research and after watching youtube videos to compare the noise difference the varex seems like a good option
Can anyone give me some feedback as to whether I should invest my hard earned $ in one?
Im looking at this one on ebay atm http://www.ebay.com.au/itm/130583220548?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Thanks
Edited by Richard GTST
https://www.sau.com.au/forums/topic/379129-varex-exhaust-mufflers/
I've sold a few sets in the past few years. None returns so far, the feedbacks on them are pretty good. But I haven't seen any one using them on high powered setups yet. (I don't carry them now, get them direct from xforce)
Their standard 3inch turbo back system worked pretty good with their cat knocked out. How ever they are considered loud.
The other best exhaust I've had was the HKS silient power system. It wasn't cheap, made only 4kws difference out of 314rwkws setup (310rwkws exhaust on, and 314rwkws exhaust off). They are pretty quite on the road.
thanks for the replies
I dont have any crazy power
atm ive only got the exhaust, r34 smic, and splitfires and it made 176rwkw on the dyno, which i was pretty happy with
in the future I'd only plan to do the usual stage one - get a fuel pump, pfc, fmic, ebc and aim around the 200rwkw mark
i think taking the bit out of the Varex that flips open and closed, and puting it between a screemer pipe and normal exhaust would be awesome... so u can flip from screamer to normal.... just throwing it out there... haha
I think you'd be better off with a HKS silent muffler of fujitsubu system, i have a 3 1/2 inch fujitsubu system , i decided this week to have a cannon welded on to see if it sounded better and it was terrible, sounded like a riced up honda or commodore ,
i also got pulled over by police for the first time, they saw me accelerating and quickly came after me like a had just robbed a bank. lol.. claimed that they saw smoke and suggested i was doing a burnout, this is just from hearing me take off from an intersection with zero boost upto 2500rpm..
so for me , id never have anything that is loud ever again..
Good quality legal level exhaust >> illegal $400 muffler.
For the price of the muffler again you get get a proper, top quality bolt on exhaust which sounds great, doesn't drone and is fully legal. Might sound pricey, but a single fine for the defective muffler and you'll have forked out more than the cost of a good quality exhaust anyway.
Do it once, do it properly. A Varex is a dodgy way to overcome an issue which can easily be rectified properly, in my opinion.
That said, if you are set on a venturi muffler, the Varex are the goods from what I've heard.
I had one on my old 32 came with the car was very loud and didn't give the crisp rb note I changed it for a apexi silent system and made it sound super mean I highy recommend the apexi system not cheap but. On my new 32 I run a rsr system sounds great not load very quite on the freeway and can be bought cheap on eBay or you may find one at a jap wreaker
Edited by Bsa
A friends dad had one on his supra, completely destroyed the 2jz sound and considering how much power he lost when it was closed he never closed it.
Just get a jasma approved bolt on. Most sound great and are legal. I've got a hks hi power and love the sound.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
