Thanks guys, very happy with the car as its only mods are Catback Exhaust, Pod filter, Underdrive pulley & a brass button clutch. Will be back for another run when i get some good tyres :)
that's a pretty shocking 60' time. some decent tyres will drastically drop that time. brass button clutch probably doesn't help if it bites hard (promotes wheelspin off the line). get the 60' time down to around 2 seconds and you should be running flat 14's.
good time mate! very impressive :)
I still need to try going to a drag strip but as nikk_666 said .. scared the time will be fail. i dont mind anything around 15 though that seems reasonable ... but since itll be my first time at drags im expecting to fail miserably :P
the fun of drag racing isnt in what time you, but the road to getting quicker.
eg my 1st run in the 33 was 19 secs because I blazed the tyres off it in 3rd.
Just get out there for a night, first few runs are generally crap and you will get better.
then once the car (not the driver) cant go any quicker start changing a few things to try and get quicker and more consistnt
Yeah I hope to pop down on the next drag night for some fun, ive been to a few skidpans and had fun with those, the instructor in the car always said i was a bit lightfooted and i could have gone much harder laugh.gif im still learning though so i figured it would be best to go slow and whats well within my control
just didnt wanna embarass the other skyline owners down there on the night with my crappy time laugh.gif
not gna bother modding the n/a skyline past what ive done really, which is good tyres, exhaust and high flow panel filter ...
will prob work on suspension/brakes after but yeah
yeah fair enough, I still say give it a rip
Go down and have some fun mate, it gets very addictive. Drop your tyre pressures down to 23psi or so, drop the clutch at 4000rpm and let her rip :)
it would appear im noobier than i thought .. i always increased my tyre pressure before going on any skidpans .. why decrease tyre pressure?
thanks for the advice though, i actually have no clue how to do a "racing start" LOL im a granny spec driver ... fml how embarassing to say this on a skyline forum!
ill head down to the drags this coming wed or next for sum lols and post up my times for you guys ... if their <18 seconds .... nothing over, that would just be embarassing to post on a public forum. in fact 18s probably embarassing as well :P
only drop your rear tyre pressure though. pump your front ones right up (unless it's a gts4). letting the fronts down will slow you down.
also, unless you have very good tyres, you are better off slipping the clutch off the line. if you have a heavy duty clutch and dump it it will just fry the tyres. this is why, even in a mildly modded turbo, you will do better times with a healthy stock clutch than a heavy duty clutch. same goes for suspension. stock is better than stiff coil overs
im confused as to whether slipping or dropping is better, i googled it and it seems to be a mixed opinion
some say dropping wear out gearbox
some say slipping wear out clutch
both are true. but when it comes to getting the car off the line cleanly slipping the clutch is better. why do you think f1 cars run a dual stage clutch system?
when we talk about slipping the clutch we basically mean taking off normally, but faster, not riding the clutch like a learner driver. for rwd cars you are best off stalling it up on the handbrake. so handbrake on, build revs, let the clutch up to friction point so the rear end starts to squat a bit. when the light goes green drop the handbrake and let the clutch up.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
