both are true. but when it comes to getting the car off the line cleanly slipping the clutch is better. why do you think f1 cars run a dual stage clutch system?
when we talk about slipping the clutch we basically mean taking off normally, but faster, not riding the clutch like a learner driver. for rwd cars you are best off stalling it up on the handbrake. so handbrake on, build revs, let the clutch up to friction point so the rear end starts to squat a bit. when the light goes green drop the handbrake and let the clutch up.
ahh I see, Cheers everyone!
I dont feel so clueless now haha, was most worried about the launch
Guys how much of a difference would getting a lower 60ft make? Now being honest, i think i'll have trouble getting it below 2.2 sec.
My times were
14.847 @ 95MPH 2.307 60ft, couldn't select 4th so let off before the finish line
14.623 @ 97MPH 2.315 60ft, Held 3rd over the line, hit the rev limiter before the finish line
14.703 @ 95MPH 2.424 60ft, Launched too hard, but managed to select 4th gear.
Next time i'll be turning up my timing slightly, running decats & semi slicks. Spewing i don't have NIStune anymore but will get it again in the future. I want to see how much quicker i can get this thing, as i'm still a P plater.
Edited by Super Drager
general rules is that every 0.1 you drop off your 60' time = 0.2 off your ET.
with decent tyres and a good launch you should be able to get down to around a 2.0 second launch. hell i was able to do a 2.187 second 60' in a fwd magna, and i was only launching at 2500rpm. i had my tyres at about 18psi.
Get the 60' down to 2 secs flat and you will go 14 flat
If it did do a 14 flat, i'd be over the moon. I'll keep working on my 60ft times and see how quick i can go, maybe when i get the Decats and NIStune done i'll be able to give a few standard turbo cars a scare :D
loved the falcon next to you...looks like every second one around here. the stockos obviously made it go faster!! :P
seriously tho, nice run other than the 60ft :), and you still got the falcon, which is much newer and normally more powerful.
nah they are too busy making excuses :P
funny thing is though my Snoarer runs 14.6s from the factory :\
Buuuuttttt doesnt take much to get then in the 11's though ;)
Not fair, you have boost to play with :P
Record it :P Shouldn't be too bad, when i ran there were two NA supras, an SZ-R and a normal SZ, SZ-R did 15.2 & SZ did 15.8. Both were catback & pod, i was actually suprised that they ran so slow, everyone talks them up bigtime.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
