Ok heres the situation, I ripped about 3000 songs to my laptop 20% of them I ripped straight to the hdd then manualy typed the song name and wrote the album name on the folder and the rest I ripped straight to I-tunes anyway I gave my laptop to my missus and copied the songs to my extern hdd and now I synced my ipod to my pc and about 1000 songs are in the unkown album/artist category anyway of a quick fix or suggestions to get the song names found?
https://www.sau.com.au/forums/topic/379455-i-tunes-geniusus/
naming the files isn't the same as putting in id3 tags. i've spent a LOT of time on getting tags perfect for all my music.
I use Advanced Renamer http://www.advancedrenamer.com/ when renaming batches of files. I think there are more versatile programs around but this one is simple to use. Although if you have to do that many songs it is still going to be a massive task. Maybe there is a program that will rename the files from CDDB.
Luke:
there's a hidden folder called on your iPod, can't remember what it's called though, iPod_Control maybe? If you dig in there, all your music is sorted in folders like V01 V02 etc etc (F maybe?) and all the filenames will be something like shze.mp3 (four random letters). Sucks, but that's how they do it.
I've used this program in the past:
http://www.macroplant.com/phonetopc/
it used to be free... not now. and by no means do i condone looking for it elsewhere :ph34r:
ok, renamed them all on i-tunes manually..took hours. Now another issue..i cant add farkn videos :rant: i drag them to the "Movies" section, clean on my Ipod on the left click on movies tab, tick the movies i want hit sync and it wont sync onto my ipod..also converted them to MP4 format..
Have you got the box ticked to say sync videos under the main tab? By main tab I mean click the ipod device in itunes then goto the tab "movies" and make sure the "sync movies" box is ticked there.
Edited by Dani Boi
Yes, i've done that, comes up, up top saying determining which tracks to sync 1/2 determining photos to sync 2/2 or something like that but doesn't seem to find the videos..
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
