Hey guys,
Hope I don't get flames for this one,
Is a cat really needed?? I have a gtt and on it I have the regu 06 Kakimoto catback with a 3" split dump/front pipe. With the stock cat.
What gains will I see from getting say the catco 3inch high flow cat?? Someone told be it's good to have back pressure, but you guys seem to live by having the best flow possible.
Plus will the catco be legal emission wise???
https://www.sau.com.au/forums/topic/379715-is-a-cat-really-needed/
The less back pressure the better.
You could always just gut your standard cat if you dont want to goto a high flow unit. But its a risk if you get caught. A highflow unit shouldnt be illegal, but it is NSW so you really need to check your local tpt laws.
Depends on your power level if the cars relativly stock you wont really feel much differce but its also nice to finish of the exhuast. If your cars not to modded juat gor for ceramic catco hiflow cat or something.
No CAT!
THE HORROR! That would make your car.....UNROADWORTHY!!! *cue dramatic music*
I don't want my family being killed by some foolish person who doesn't have a CAT on their car!
THE SHAME!
Sorry, I couldn't help myself.
At the end of the day ya car is probably illegal is some way. Spend the $170 and get a highflow, or spend $50 and run a decat. Its your choice. BUT.........if you got done for emissions your highflow would not pass so it is safe to say that you are unroadworthy anyway.
If it is yuor daily, i would suggest being as legal as possible.
If it is your weekend toy........thats a different story.
Nah I'd like to keep it as legal as possible, plus I like to collect my stock parts for such a day.
I'm running "turbo back" exhaust with the stock cat lol. Air filter and 10 point boost. That's basically it. Much increase you think??
They can send you for an emissions test under suspicion can't they?? So even with a catback and everything stock you could be in the same position??
If it's going to be an upgrade I'll do it but if it's minimal I probably won't bother.
I'm running "turbo back" exhaust with the stock cat lol. Pod filter and 10 pound boost. That's basically it. Much increase you think??
if they send you for a test, just swap out the decat before you go. if youre still running the compliance cat then removing it for either a high flow or a decat will make a difference.
the only way youre gonna get caught without a cat is if youre foolish enough to go through an emissions test without one.
............or, if you happen to be unlucky enough to have a Police car behind you at night and they see flames shooting out of your muffler >_<
Short answer, if they suspect your car may not be EPA compliant, be that for noise output or emissions, then yes they can defect you and send you to the EPA.
By the sounds of it on your lightly modified car there is no massive gain to be had running no cat - If your car was pushing out 400kw and you had a serious exhaust restriction then it might be a different story, not to mention that the fine for being caught with no cat is around $10,000 from memory.
i realise that but my point is if youre sent for a test, just put the stock cat back and pass it. they cant give you a $10,000 fine on the side of the road. also afaik that big fine is only for workshops no?
That will work if you are pulled over and sent off for an EPA test, however if you are unlucky enough to get caught in a joint Police/RTA/EPA defect setup then its a totally different story, so while you'd have to be VERY unlucky to get pulled in to one of the full house setup's, the fact is it can happen, and you may have a tough time trying to talk your way out of it to an EPA official when they have your car strapped to a dyno at night to check the noise and it starts blowing flames out the back.
I think you will find that the EPA can fine you on the spot just as the Police can.
I would strongly recommend a 100 cell metal cat, I bought mine from Venom and it was only $60 more than a ceramic 200 cell cat from just jap or others. Venom can sell them with the factory flanges so it just bolts on.
That will mean that you cant get an on the spot fine as you have a cat. If you do get sent for an emissions test I would still recommend changing it back to the standard one though to be safer.
Yeh we have the road-side tests here too, but they don't strap you onto a dyno. They just have emissions and noise testers that they use while your car is idling and they rev it to 5000rpm in neutral.
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
