Oh well too late to edit lol
See how you go in the other city's man.
Going to Miami?
Isn't that where the bishes at? Rollerskating beside the beach in their bikini's and where all the jacked up guys go?
its autumn, heading into winter and currently 25 degrees. Meybeh in summer?
Aaron you've been to Hollywood? and downtown LA? Jumped on the freeways?
yeh I have, visited universal studios before following through to Hollywood.
and freeways? yes, drove from Canada through to new york. went to the buffalo on the way to meet the racist's, stopped near new jersey as we got lost, and then to new york..
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=130590983037&ssPageName=ADME:L:OC:AU:1123
looks pretty average.. i'm only going to do the passanger corner where the crack is, and carve out the outline so it looks a little real.. not fussed though.. just to cover the paint cracks
she couldnt get the hall until next year. and the days she could get the hall, she couldnt get the church.
shes up the duff so it needed to happen soon.
Wedding was really good, I ended up DJ'ing half of it. n I dont think too many people cared about work the next day, they were all smashed..
love going to weddings. atmosphere is always great!
i dont have a DJ name.. to be honest DJing is shit and boring and a hassle.
ToniTonyTone - I'm with TPG and they're useles. I have ADSL 2 and the net keeps cutting out when the phone rings as if Im on dial up.
I have TPG, they're...ok. Have improved lately, used to be really crap, especially in summer.
Naked adsl still needs a phone line, they just remove your ability to make/receive phone calls on it
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
