The thread topic is usually a straight up give away if the topic is going to be good or not.
Then you read the first few post, if it's all shit talk = Shit thread.
Constructive discussion = Good thread.
Nisskid has the know-how.
In one thread, he was explaining to us about the types of wheel qualities and builds through out different brands.
LOL! For the trololols!
I bought a sticker set from On The Run Motorsport.
Lol they about me for having varrstoens, then I ask them about stickers and no one says anything.
Muski is a good guy too he helps out too
Now they're starting about my latches on the front bar lol.
Ryan, tell me something, why do NS'ers worry so much about other peoples cars?
actually i too was wondering what there for, quick bar removal?
yeh sort of.
did a driver dynamics day and kind of got ahead of myself and went into the first corner sand trap. it ripped off the front bar from its mounting...
jono below im pretty sure saw it happen.
but now it takes me 30 seconds to get the front bar off when i need to so its pretty useful seeing as im always pulling shit apart.
Is correct i believe.
I'm gonna lose my licence on this bike, at least you 250 riders can wring your bikes to their limits. I can't get out of farkin 1st gear :(
Need to track...
it's easy you just click up :happy:
mechanic just picked up my bike, he recognized it soon as he saw it says he's worked on it before
f**k this flu. f**k it to hell
+1
you get booked?
Nah man, but if I keep riding it I reckon I will. Can't have fun on it without breaking a lot of laws :/
Remember the first few days of owning a turbo car, how easy it was to get up to speed limits and find yourself surpassing them...multiply it by 11ty :/
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
