want pho sooo bad... but CBF going out of the house....
also Bun Bu Hue is probably a bit much for a noob... it's generally pretty damn strong with all the shrimp paste and lemongrass
Try the bbh in st albans (y)
Then again. Thats too far for ya. Best bbh in melb.
