I think u can bring two people.. Well last time I did. Just bring cash because if u pay card they won't accept your card unless pay pass
yeah that really whack
we have 2 cards as a business account, I have the primary one and Katie has the household one.
we go in and I don't have my card on me. but katie has hers.
but no I'm not allowed to pay as my debit card has a different name to the cosco card.
such a pain
such a pain
yep. ts stupid if you ask me.
Yup. but i work sat/sun this weekend, so if before 3pm, i'm in =P
yeh if it ends up being later just give one of us the money
Alvin you work at Jap place in Essendon yeah?
do you work thursday's?
edit: make that tuesdays
moonee ponds, chiba,
the essendon one is tookaiya? heard is pretty good too. and yes i'm working tue thur fri sat sun this week.
next week?
and food good?
need a pre abandon the fiance meal.
and japanese is about as far removed from german food as possible
We're pretty popular, and i'm quite a big fan of the japanese gyozas. Sooo, judging from how popular we are, i'd say food is pretty good. Though sushi standards are the best on tuesday and sunday. new sushi chef isn't as good as the one that works on tuesday, and the previous full time sushi chef only works on sundays now.
Next week, its hard to say, but i'm normally working on tuesday.
A friend really enjoyed Chiba in moonee ponds and highly recommended it to me.
What do you do there Alvin?
am a waiter. but i normally only handle the bigger tables, and regulars.
I also boss all the other wait staff around.
And, theres a taiwanese waitress that's pretty cute, though she's like 29,
Japanese girl called manani is not too bad as well, and korean chick lauren also pretty quality. But not sure when they work. LOL
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
