Did a road trip to Moama, mate was in his Prelude. They have the non memory position diver seats like Skylines...I joked to him at the end of the trip that it'd be funny if I adjusted the seat (he was OCD about his seat's position and hated not being able to get it perfect after someone's fked with it), he took my joke very badly. Gathered Preludes aren't comfortable cruisers.
Oh well, enjoy Ric.
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
