im going to do new plugs on next service in 500km any suggestions?
im going to get a high flow panel filter and ill clean the afm no problems
but atm probably cant afford a O2 sensor
  • Replies 72
ive never had the light on the dash and have twice had the pin under the empty line
pretty sure that the low fuel light is operated seperately to the dash gauge. as i said earlier, it generally comes on with around 10L left before empty, so if you have never gotten down to a point where it has taken over 55L to fill then you haven't gotten the tank low enough
correcto mutcho, when you pull the sender unit out you can see a switch thing on the very bottom of sender unit itself but it will only work if the float touches the switch on the unit. So if the sender is giving false readings saying your are empty (fuel gauge can be on 'E') but then the float will not be in contact with the switch on the assembely because you still have more fuel than what its showing on the gauge.
Edited by central coast person
well im not sure what to say but the fact is that its the O2 sensor that causes poor economy, particularly if u are still getting poor economy when driving the car nicely.
They are less than $100 delivered from the business traders on here n u can change it yourself- peice of piss...
do you have an ECU you can tune with?
If not
I dare to to put a tank load of E85 in the car and run on the standard ECU....post video's for lulz
i dare him to put a tank of e85 in and then try to drive out of the driveway of the servo without needing a towtruck, LOL
fixed your post for lulz
Just an FYI, my search for a glaring face on the internet lead me to imgur.
From there I proceded to redit.
From there, I proceded to very random places.
And hour later, I had forgotten about this post until I was closing my tabs ><
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
