put a bulge in the bonnet where the cam cover will hit it, do it in metal and without buchering the reo too much and the cops wont bother you
Z32 bonnets are aluminium, god luck.
I had a z32, and cant see the point, a vg30dett is probably the nicest of the nissan motors with that power to drive, mine made a nice torquey 250rwkw with only exhaust, chip and front mount(and 14psi) Drove like that for 2 years
https://www.sau.com.au/forums/topic/380601-rb30-z32/page/2/#findComment-6088753
Taint that hard, plenty of aluminium welders in this country!
https://www.sau.com.au/forums/topic/380601-rb30-z32/page/2/#findComment-6088764
Vq35 or vq30det?
All better, agreed. However, if you read my previous posts, I would not choose this platform to modify in the first place if i had funds, and not buying a house.
So, thats where the SR20 idea is coming into play now:
- 4cyl - cheaper to run & maintain
- z32 box adapter to sr20 readily avaliable (so cheap)and the box will hold up fine to abuse.
- Car itself still looks ok and modern-ish
- Still has faily large aftermarket support. All i would get would probably be some suspension mods, besides the standard cooler/zorst.
I know its not ideal to have an 4cyl in it for the weight, but i dont have much of a choice with my budget. Car would be a daily, and weekends up in the hills.
As for, why not keep VG30dett, well i dont have tools/knowladge to work on it with those space constraints, so this would fix that prob.
Not looking at breaking any records with speed/handling, just want a cheap turbo car - while trying something different to your 1 million skyline/silvias around...In my opinion, with little weight reduction, suspensions mods and hopefully around 200rwkw from the SR, this could be a fun hills/daily car.
https://www.sau.com.au/forums/topic/380601-rb30-z32/page/2/#findComment-6090792
LOL, i have shit all mechanical knowledge and i can work on my 300ZX without a problem. As for fuel consumption, good luck, your putting a weaksauce motor into a heavy car so you'll need to rev harder to go anywhere. Also a VG30DETT will pull 200rwkw with an exhaust & pod filter, with bucketloads more torque then an SR20. I've seen more modded ones do 270rwkw on stock turbos.
https://www.sau.com.au/forums/topic/380601-rb30-z32/page/2/#findComment-6090844
You're talking about doing an engine conversion because you don't have the tools to maintain the factory engine that is in there.
I don't feel like I should have to point out the issue here.
If you've got the tools and expertise (and money) to do an engine conversion, then maintainng a vg30 is a peice of cake.
https://www.sau.com.au/forums/topic/380601-rb30-z32/page/2/#findComment-6093206
Im all against engine-out jobs just to change turbos. But hey, if thats what you call "a piece of cake" then good for you.
https://www.sau.com.au/forums/topic/380601-rb30-z32/page/2/#findComment-6095003
Well the engine has to come out anyway if you are doing an engine conversion. Also removing a vg30dett from a z32 is a peice of cake compared to doing an engine conversion. This is based on owning both an r32 GTR and a z32 300zx. Provided the turbos are looked after and run in the appropriate boost range (up to 14psi on stock turbos) they last at least 100,000 k's. Mine have lasted 120,000 k's. Removing the engine every 100, 000 k's isn't exactly onerous.
But hey if you want to do an engine conversion, with a smaller engine with no vct, and which requires an engineer's certificate, with the intention of saving money, then good for you. Would be interested to see the write up and how much money you saved at the end of it.
https://www.sau.com.au/forums/topic/380601-rb30-z32/page/2/#findComment-6096339
Lets agree to disagree. Besides, if we all drove the same cars, wheres the fun in that :) ?
Definetly will have a write-up on it. Yes, a budget project only because i have a huge ammount of parts already that i can use on it. If i had to buy from scratch...no way.
https://www.sau.com.au/forums/topic/380601-rb30-z32/page/2/#findComment-6096435
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
