Ok so, my car is shit, that's a good start.
but seriously
I always road tune my car, just do it myself with the data logit package etc.
Thought, hey why not throw it on the dyno and have a quick look at where i am at.
I'm about to upgrade the exhaust and thought it would be interesting to see what difference is made and was thinking of helping out this site with some real world data etc.
my car ......
R32 GTR
R33 rb26 stock bottom end
JUN 264 9.7mm
700cc sards
z32 AFM's stock airbox, KnN panel
2860-5's
exhaust is...
HKS copy dumps
some no name s/s front pipe 63mm x 2 into 3"
3" decat
HKS super dragger
The dyno i used is a Dyno Dynamics with latest software etc, owned privately.
The owner has tuned a few cars but, he left me to my own to use his dyno etc and just go for it.:teehee:
This is great for me, because i love playing with this sort of stuff etc. Not awsome for when i would like support.
When i went i hadn't slept for 23 hours, because of night shift, yep, shit idea, so i really wasn't on the ball on the day either, :wacko:
any way, results....
Top graph boost and tourqe
bottom kw and AF
dont laugh......
Edited by blue_vl_t
https://www.sau.com.au/forums/topic/380762-my-laughable-dyno-results/
  • Replies 48
You think so?
I was thinking i was running 1.5 bar, i have a 1.5 bar gauge and upped the boost until i thought it was at the top of the gauge,
so was quite shocked to see what his dyno had to say, assuming i was running 22 psi max, i assume his sensor is reading ok???
I will fit a better gauge soon anyway to see for sure.
I really think the top of the graph is really flat.
perhaps indicating an exhaust upgrade, which i will be doing regardless.
one other thing i was thinking, with the stock air box, i only run the stock air feed, i will remove the 'chamber' from the botom of the box to see if the extra 3" hole makes much difference.
really looks like a restriction to me, the power just rises and stops dead, then flat lines......
I have my theories, but i'm keen to see what people think if could be
I have some HPI 3" dumps and twin 3" into 4" system to go on, just needs a few more bit modified etc. should be soon
Also i do have some cam gears, but not fitted, mostly because they are ebay ones, and i'm unsure if i should trust them???
true, i only have a cheap ass turbotech valve on it too.
Before a retest i will
remove the chamber from the air box
install a EBC, probably Profec B 2
install the new exhaust.
Triple check the cam timing and base ignition timing.
funny thing is, with any more than 14 degrees of timing the power seemed to drop, unless the heat soak make s a huge difference??
Ahh the joy of learning :laugh:
It also looks a bit lazy onto boost... I know -5s aren't exactly punchy on a 2.6L but surely you should be hitting 20psi a bit earlier than that?
I was thinking this also, "big" (lol) rush of power seems very close to 5000rpm on the street :unsure:
Edited by blue_vl_t
Ill bet with the new exhaust you will be able to run a heap more timing and pick up some response to boot.
lets hope so.
I really wanted to do a before/after test, will be good for me and the forum, if it makes the difference to push power over 350rwkw where it should be i will be quite shocked!!!
Im just running off actuators and a bleed, on much sooner than you are :)
Fix the exhaust, also check the cams are correctly dialled in, that can often be a problem.
Get 20psi holding rather than falling away to 15psi and you'll be right.
on the top graph, the boost is dropping from 27 to 25 psi, fairly sure thats right.............
Oh yes indeed, looking from my phone again, i should stop doing that :(
The boost graph is even lazier then than i thought now im looking from my PC.
Definately exhaust and get the boost control sorted so it comes on much earlier like it should. It still could indeed be the cams not dialled in correctly too.
No thats wrong, thats your torque. Notice it starts way off the charts for what you could consider vacuum? Whereas the other one is accurate for what you expect.
Your boost is hitting 20 and bleeding down to 15.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
