Hi everyone
i just got myself a r34 4door for drifting (unlicensed)
mods: fmic, bov, pod filter, power fc, boost controller, brand new nissan H/duty clutch, exhaust.
also has suspension already
the car is sitting on 12 psi making arond 280 hp
whats the next little items i need ?
And the H/duty clutch hasnt gone in yet so if i should get another one just let me no please :)
cheers
https://www.sau.com.au/forums/topic/380780-got-a-drift-car/
As above plus save the money you are planning on mods to maintain the car, no doubt you will need new front and rear bars, lots of tyres etc
Dont get into the trap of constantly modifying stuff, Wait until you have oerfected sliding the car as is before chasing more power etc.
https://www.sau.com.au/forums/topic/380780-got-a-drift-car/#findComment-6071852
here she is
You'd probably want to lower it for better stability and handling for drifting.
Work on the Suspension / Braking / Tyres.
Power mods is not necessary if you are just starting out.
All should be good.
https://www.sau.com.au/forums/topic/380780-got-a-drift-car/#findComment-6072064
All should be good.
Why?
It would just f**k the roll centres going any lower than that
https://www.sau.com.au/forums/topic/380780-got-a-drift-car/#findComment-6072069
braking?! standard calipers would be fine.
Get it out to the track, fix shit you break and when you feel your ready for more power, or more lock then go for it.
Oh, a must have is a good, supportive seat it makes a world of difference.
Edited by Run-It-Hard
https://www.sau.com.au/forums/topic/380780-got-a-drift-car/#findComment-6072075
Just get as much track time as possible, seems like it's a decent base to learn in already.
1000 times this.
Your car is pretty epic already, just get out there and rip some skids :D
Maybe invest in a gopro too so you can not only upload to youtube and show off your maaaaad skills, but you can watch your videos and see what you can improve on and maybe get other pro people to comment too.
https://www.sau.com.au/forums/topic/380780-got-a-drift-car/#findComment-6072098
That's just me.
Upgrade brakes to take a higher heat range and more response.
Each to their own.
And yes, a racing seat will make a difference.
https://www.sau.com.au/forums/topic/380780-got-a-drift-car/#findComment-6072334
most important mod = welded diff / 1.5 way or 2way
Negative, I learn't on an open diff. If anything it'll be better to learn with less. You'll then realise how things work/make it easier when you start adding parts to the car.
VLSD would be fine for now.
https://www.sau.com.au/forums/topic/380780-got-a-drift-car/#findComment-6073023
That's just me.
Each to their own.
upgrading brakes is just a waste of money on a drift car, you won't have any issues with stock gear and half decent pads
get a decent seat, make sure the diff is locked and go drifting, you don't need anything else
dont get a gopro if you buy a camera as there shit :down:
just lock the diff, drifting without a diff that locks it just a waste of time and it won't teach you anything
Edited by driftnick13
https://www.sau.com.au/forums/topic/380780-got-a-drift-car/#findComment-6073029
i think the car has a 2 way diff now :) and suspension i dropped and is tucking 18'' tyres and has got a recaro bucket seat, brakes i will needa replace and what sort of clutch do i need? i got a H/duty nissan clutch but its brand new and not in the car yet
long story short...... it was my brohers car, he go it from SA and didnt license it, then f**ked the clutch so parked it up and owed my dad 13k so dad said that he will keep the skyline and dont worry about the bill and dad gave it to me :) :) (daddys boy much haha )
so yea i no the cars back ground and everyhing :)
and yes theres a 33 gtst (mine) 34 gtt (mums) 34 gtr (dads) 34 gtt (sisters) and yea....family of skylines
https://www.sau.com.au/forums/topic/380780-got-a-drift-car/#findComment-6073265
Fuuuuuu, you lucky bastard! hahaha.
Sounds like your car is good to go mate, you've ticked pretty much every box we've suggested.
Just get a fire extinguiser and I think that'll do it. needs to be at least 1kg and have a metal bracket then placed with in reach of the driver.
That clutch should do ok. I've got a Jim Berry Full Monty for sale if you want it pirate.gif
https://www.sau.com.au/forums/topic/380780-got-a-drift-car/#findComment-6075008
Speak to ISC-PERFORMANCE and get a set of n1 coil overs, rear camber arms, hicas lock bar, front caster rods, rear traction rods. Then just get used to the power you have now :) also a 2way diff is a must. Also make sure your handbrake is upto scratch.
https://www.sau.com.au/forums/topic/380780-got-a-drift-car/#findComment-6076936
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
