Have a highflow turbo for sale, still on the car so anyone interested can see it working
its a gt2871r 56trim core with stock r33 housings so will bolt on and look completely standard
does not smoke and in excellent condition, perfect for stock replacement, has steel turbine.
looking for $700 ONO
https://www.sau.com.au/forums/topic/380806-standard-hi-flow-turbo/
Hey mate if my turbo sells I'll take this ....
How many ks are on it
i bought the car with the highflow already done, id say about 40 000k's, its in very good condition, if you live in brissy you can come see for yourself
Ok sweet mate as soon as mine sells I will !
What boost are u running through it also
it has been running 14psi using an ebc since it was tuned, have tried higher but my injectors are leaning out
still for sale $450
also have the 3inch dump thats bolted to it for $150
Great upgrade for stock replacement, straight bolt on upgrade, full boost under 3000rpm
still for sale $450
Why are you selling it? Also brand new dump-front pipes are $150. What is so special about yours?
The turbo is SOLD now, was selling because i want to upgrade to a gt3076
where do you get 3inch dump pipes for $150 new???
can you get me one for a garrett for this price? if you can im very interested lol
Edited by SliverS2
ah ok, fair enough, anyone interested can have it for $60 then. its an X force bellmouth..
:whistling:
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
