Hi, had enough of the auto in my R31 . .want to change it to manual and have all the parts required EXCEPT for a NEW flywheel, can anyone here recommend a place in perth to get one from? im not looking for a lightened flywheel just a standard type for street duties
thanks in advance
https://www.sau.com.au/forums/topic/380869-rb30-flywheel/
Most Auto RB Cranks have the Manual Pilot bush also, Remove the Steel Flexplate Hub and see if the thin bush is there,If so clean it well and lube it if not you can buy the bush from any Nissan dealer. Nissan have used the same bush since the late 60s on most Nissan/Datsuns.
Edited by N I B
https://www.sau.com.au/forums/topic/380869-rb30-flywheel/#findComment-6081500
thanks N I B . . . i thought i would have to go genuine but it turns out veale in Redcliffe have them so i got a new bush for 8 bucks
it will be a spare if my crank already has one!
https://www.sau.com.au/forums/topic/380869-rb30-flywheel/#findComment-6081614
i will suss it out this loooong weekend but from the QUICK glance at the motor i had last night im gunna have to put the bush in. . .jonno do i use a socket/grease to install the bush?
https://www.sau.com.au/forums/topic/380869-rb30-flywheel/#findComment-6082849
once you have the auto one out clean out the crank as best you can then soak the new spigot in engine oil then tap it in with a socket and hammer. make sure you use the right size socket as its very soft and distorts easily.
https://www.sau.com.au/forums/topic/380869-rb30-flywheel/#findComment-6083097
either pack it with grease and find something thats a tight fit inside the auto one and bash it into the crank or if that doesnt work weld something to it (without touching the crank) and weld that to a chain or similar and give it a tug.
https://www.sau.com.au/forums/topic/380869-rb30-flywheel/#findComment-6083139
when i converted my Ti, had to remove the auto bush and replace it with a manual bush.
I did mine at a mechanics workshop though, on a hoist. Feel sorry if you have to do it laying under the car.
Need to seriously work on my ti haha
https://www.sau.com.au/forums/topic/380869-rb30-flywheel/#findComment-6084330
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
