  • Replies 43
Same lol...Its lacking the elevation changes of lakeside to be an interesting high speed circuit.....Driving to the post office seems more interesting than EC north.....It would be fun on a bike though...which is what EC was made for in the first place iirc.
Wonder what the South circuit will be like????
A downforce car with a bazzillion horsepowers would likely make it interesting, ....... but where do ya ever see those?!!
And a bonus is the vast majority of the track is visible from the top of the pits.... which could be handy for some events I guess.......... ***COUGH***
(I'm really only speculating) :D
It looks like it would get pretty mundane quite quickly, which is a shame as EC is so much fun. Turn 4 is my personal favourite so it's a shame to see it go, but if it allows for more days then it's understandable.
An SR8 around there would be abit of fun though!
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
