  • Replies 886
Il post up a new thread with all the issues I had since the hypergear installation and what I did to fix them
Edit, il post it in here first and if there is a problem with what I say I can fix it before I create a reference thread.
Edited by lilcrash
Problems/issues installing a hypergear atr43ss-1 turbo.
1. Fouls on heat sheild on manifold - cut piece out to clear housing, dint the heat shield or use 10mm flange spacer.
2. Rear housing is 20mm longer - move all exhaust mounts forward 20mm
3. Water lines don't line up - get custom made lines
4. Oil drain on awkward angle - custom made oil drain
5. No boost reference nipple in turbo - weld on into one of your custom pipes
6. Needs custom intake - make custom intake
I doubt its the headgasket. Do a comp and leakdown test. U have been running 25psi. I would be a little concerned whether the tune was safe for that amount of boost. May be alright.
Clean all cooler pipes and catch can etc. Try running with catch can not connected to the turbo intake pipe. Run it into another can or bottle etc and monitor whther its still spewing out oil
I'm doing a comp test tonight, if it isn't head gasket i think it's deffinately rings. I clean up all I could reach, and have now swapped the intakes over until I can resolve this oil issue. I was steadily accelerating holding the throttle at 18/20psi when I started to smell the oil again. It only hit 25 psi 3/4times I don't feel it's safe at that level.
Ok turns out my engine is just rooted.
91,167,167,168,167,167. That was engine still hot, many burns on my fingers :(, poured oil into cyl 1 and it came up to 130psi. So yeah head gasket?
Air shouldn't be going past the piston rings..
You've Got some serious issues.
And when runnin that my boost, why the hell aren't you running a proper electronic boost controller?
Skimping on one of the most critical parts?
Can't be a head gasket if oil brought the compression up that much from 90psi.
I'd say that cylinder is about to grenade so I wouldn't even start the car anymore.
And if this is a standard engine, why the hell are you running 25psi of boost?
Seriously...
Are you getting paid to troll? Cause the more you reply you just add more and more f**kin
stupid comments...
First it was the tune, then the actuator, oil blowing out the ass end, headgasket...
Wats next? The chain slips on the sprocket? or it wont go into lo 4x4?
Take the f**kin thing to a mech and get them to solve it cause clearly you cant even let
alone describe your problems.
And the oil spraying could be because of the current problem could it not?
Boost issue still isn't completely resolved but clearly something has gone wrong somewhere. And as for the tune well that has absolutely nothing to do with me.
Yeah your oil problem could be as dramatic as it is because of Cyl 1.
Sounds like a cooked piston fr those symptoms (busted ring lands, crown) and that would let combustion pressure into the oil system.
Well there you have it. Get a 2nd hand motor and fix it. Consider taking it to a mechanic.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
