  • Replies 886
Ok I'm sick of reading different opinions. What is the consensus on running in a rebuilt motor. I would like a step by step from the moment I pour water and oil into it if possible. I don't want there to be any chance of me stuffing it up.
Thanks in advance.
I recommend you get someone to do all the work for you with warranty, otherwise I reckon we'll be soon reading another thread titled 'fresh engine installed, but still having problems'
ok so here is some more info, one of my valves in cylinder 5 was about to drop in, and my head has marks from where the head gasket was soon to blow. so looks like i pulled it down just in time. on another bad note, when i had my front guard replaced a few years ago they dodged it up and used a holden indicator bulb holder and just electrical taped it on to hold it together so now my clear indicator housing wont work :@ another call to just cars to get more repairs done, glad they have life time guarantee on repairs. this is the 4th time it has had to get repairs done.
and a strange question. i need to provide my stem seals and cam seals for the head to be re assembled, in my gasket kit there is a packet with 12 stem seals, a packet with 12 stem seals and 1 big seal (looks like a cam seal to me) is there only supposed to be 1 cam seal? the only other seals in the kit is a packet with 2 seals the same as the cam seal and a rear? oil/main? seal. could one of these be the other cam seal?
Why would you strip an engine down for a rebuild and use 2nd hand parts if unsure of the condition?
If you can replace it and your not sure of the life condition...replace it while you can.
Last thing you want is a fresh built engine, 2nd hand oil pump, final tune, youll head out and give it a boot full and
hit limiter a few times and then the collar or something fouls
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
