  • Replies 886
yeah i meant i would be doing all the stuffing around while on the dyno. if its all caused by detonation then there is my answer, i didnt realize detonation could wear out rings. but it is good to know that the tune is to blame. so thanx *** *********** for all the problems you have caused, apart from the oil pouring out which was caused by the rings dieing due to prolonged detonation im guessing. that same detonation sound could be heard from the second i picked up my car, thats half the reason i called them 10 minutes after i picked it up, and never got a call back.
oh well new motor and new tuner, lets hope it all goes well.
25 psi was the problem not the tune per se. Please understand this FFS. Just a few secs of det at this boost level toasted your motor not 'prolonged det'.
If you go back far enough the issue was setting up boost control on an untuned stock ecu and had moments of uncontrolled boost. Was warned not to do this.
Advised to get engine management asap and to drive the car gently until tuned but he continued to set up boost control with different actuators with an untuned Nistune. There was audible knock while doing this. On more than one occasion.
Then finally took car to EFI for tuning.
IMO the damage was done prior and EFI were left with a sick engine to start with.
i wish i knew if it had been tuned at all, if they did actually tune it, im not sure if they actually did now that i think about it but thats not for discussion at this current moment, i would assume it was tuned with the 20psi dropping to 14 psi.
im sorry i that didnt realize that even boost cut was too high for engine to run at for the split second my hit it oh wait that has been happening for 3 years with the stock turbo.
Yes, meaning it wasn't tuned for 20psi in the correct load cells. You put more load on the engine and add more boost without tuning for it then of course it's going to detonate.
I don't get your comment about the TP cut. If you increase the boost at all over factory then there is a chance it will detonate. This is why you get your AFR's checked when you do modifications like that, you don't just let it hit TP cut for 3 years thinking that means it is safe :blink:
I only ran the 18psi for a short drive, I thought it had the smaller actuator on, later confirmed that the smaller one was the second one in the box, until I took the car to the dyno I had the 7psi actuator on and wasn't revving past 3500/4000 as that's when it got to 10psi.. I swapped it about 30mins before I got to the dyno and I drove very sedately for those 20km.
And no I didn't have any audible knock as that only hit at 6000ish rpm. That all started on the way home, that's why I was concerned.
The boost cut issue wasn't something I tried to make happen, it normally made 11/12 psi. On cold mornings it would spike ocasionally without warning.
And before this gets turned against me too, yes every time it happened I turned it down a bit more.
Edited by lilcrash
I'm not sure, the machinist hasn't touched the block yet. I've had to put it off until I have more cash. Christmas has emptied my pockets. But with any luck I should have it back on the road and fully tuned for my birthday in march. If I decide to keep it. I'm wondering if someone would be interested in buying it before i even turn the key. :/
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
