  • Replies 886
Come on. What's your prediction.
I only assumed turbo failure because it stopped making noise and my exhaust got really quite. Zero induction noise.
I'm at a cross road now. My chosen tuner has started working at a workshop that I will never let my tires roll into ever again.
My prediction is that you are going to spend many many more dollars.
Then sell it at a massive loss.
Then buy a corolla wagon.
but the legend will live on for ever on SAU..
"Hey remember that Stagea" they'll say..
and the other one will go "lol.. yeah.. man that was some crazy shit... it was like watching a train wreck"
anyway...
I have no doubt that JEZ knows what he is doing.
But to drive 800km to get a tune is retarded of the highest order.
ESPECIALLY cause you are not willing to get a local person to at least do a quick tune of the cruise area of the map.
Your mindset of not going to EFI/ERD is proper retarded too.
apart from you, not a single person has ever had ANYTHING bad to say about that mob.
and you won't even explain why you won't go back to them apart from say "i had a bad experience..."
did they not print your receipt on recycled paper or something? and therefore are murderers?
anyway, I'm glad this thread is here because it is entertaining to read.
Carry on.
anyway...
Carry on.
Problem is if he does take it there, and his shitty engine build with missing gaskets and only god knows what else, blows up, then he'll blame the tuner.
I'm curious as to how you have come to the conclusion that Efi has never had any other complaints. There is a long list of people who laughed at me for taking my car there, at the end of the day no tuner is going to get it right everyday. My problem wasn't so much with the tune, but the after tune questions. When you have a customer ring within minutes of leaving because things are going wrong, do you ignore it or ring them back when you get a chance? I'm not sure about you but when i get my car tuned then get a check engine light come up I worry.
I understand that you will all have your opinions of my engine build and that's fine.
Im very much past mouthing off about what was done to reduce my view of them and I think it's best left untold.
I agree that a few over boost situations may have weakend my piston and then it cracked under average driving conditions. There is still no answer to my boost problems and I'm hoping that these will be resolved this time it's on the dyno.
Edited by lilcrash
Seriously...
Does this thread need to live after this?
I knew this would happen but oh no a few members have faith.
After reading "oh my turbo stopped making noise" this kid has NO f**kin idea wtf is goin on.
An engine thats held together with hopes and dreams?
f**k me I wanna see this bad boy run 5bar through a stock turbo, might make some wicked sick
numbers.
Just jack it up and floor it in the garage at home and tune it like that I reakon, its about
as good as wat youll get from this build or slap together as Ill call it.
you guys are fucted, seriously...
yep he has made some strange mistakes but he is learning along the way...
I dont necessarily agree with his methods, but its like reading a book, I just dont know what will happen next when I turn the page...
I definitely hope it all turns out well Steven, but yeah more investigation, research & knowledge before jumping in and doing stuff is good advice...
800ks on an untuned freshly built motor, not the most sound logic...
I get the impression that most of you think this is my first car. Precautions were made before I did any excessive driving. Everything in the engine has been double checked. There is the same problem ratio as if anyone else had built it. At the end of the day if it dies its my fault. Things happen. I've made all the precautions I can.
Seriously...
numbers.
I honestly, for the life of me, can NOT figure out what your problem is. Seriously, I wanna know. What's it to you? Why do you care so much? Honestly, I couldn't really care less whether Steven's rebuild works or it doesn't (no offense Steven). It's not my car, why would I? But I still wish him the best of luck with it, and I'll follow along and offer any help or advice that I can because that's just what you do. So why are you so desperate for this to fail? Are you really that narcissistic?
Ok just want an opinion on what actuator I should attempt to use for my tune.
Low pressure - 6/7psi that creeps to 16-18psi with a boost control to try to get a constant 18-20psi
High pressure - 16psi sometimes normally 20psi that drops to 14psi with a boost control to try to hold boost on.
Logically I think the low pressure would be the smart choice but just want a second opinion.
Ok I tested the actuators on the bench,
Mid actuator - starts to move at 2psi, 100% at 28psi
High pressure - starts to move at 20psi, 100% at 50psi
I haven't tested the little one as its on the car.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
