  • Replies 886
Chocco PM sent. Be nice.
Lilcrash gravity rules over oil too, so find the highest point at which there is oil,
If its only around the top of the oil pump then it may be the oil pump gasket = engine out unfortunately
But check its not coming from the cam covers or cam seals and running down behind the black timing cover backing.
When u noticed the leak was it dripping?
There is oil splatters all over the rail that runs under the front of the engine (the one with all the holes in it) and a few drips on the floor. But it must be pretty minimal because there isn't any oil missing from the sump
Are you sure there is no way to do the pump without pulling the engine back out?
Make a thing that hovers engine in its position, like across strut towers, remove the frame part that holds your wheels? and engine mounts, and sway bar, bingo. If you have a hoist and the tools it'll be easier than engine removal... I haven't done it but did think about it.
To me it looks to be above the oil pump. If it is the cam seals il be happy.
Someone said you can pull it out enough to do the seal without sump off, or do as I did and just high temp sealant it. Took me 2 hours to pull everything off, stop posting and get pulling apart son!
Ok so I ran it without the covers and there wasn't any oil coming from anywhere. As far as I can see the oil is just coming from no where. I'm going to degrease it all and see if it comes back. Maybe I spilt more then I thought.
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
