Hi Guys,
I want to modify my intake manifold to be a front facing TB and while i'm at it i want to use a larger TB(one with a throttle position senor) but I have been told that the powerFC will not support the larger TB modification. I just want to confirm this off some other people, has anyone successfully upgraded there throttle body while using a PowerFC?
Edited by megzz
https://www.sau.com.au/forums/topic/381659-larger-tb-any-potential-issues/
the throttle body is not the issue, its the cutting and shutting of the manifold which will destroy the flow of the intake manifold and cause you engine problems later on.
get a decent intake manifold, even the china greedy copy is better then a cut and shut job
Had one on my 3L. Was awesome. Just don't buy the eBay ones, they leak and the finish is really shit.
You can get them for about $350 from an Autobarn store, and they come with all bolts, hose fittings etc. even have a little section where you can put your greddy sticker, so you can tell the poor kid that you sell your car to that it has a blow off valve, and greddy intake manifold.
The larger TBs bolt straight on too. The standard one needs an $80 adapter.
greddy plenum with q45 TB. bolts up and use std tps :thumbsup:
I thought only that only applied to RB20 and series 1 RB25 :blink:
I'm running a Q45 t/b on a custom plenum and the RB20 TPS bolted straight up.
The only possible con with the Q45 t/b is it can be a bit touchy at low speed but you get used to it :thumbsup:
you can get an RB25 intake manifold form autobahn for $350? I better check these out. W
hat car is a Q45 throttle body off?
Sure can - Mine was a polished finish too. Looked great, But I painted it black, because cops are like a few types of birds - They're attracted to shiny things.
Also, your answer to the Q45 question:
(Straight off wikipedia)
The Infiniti Q45 was a full-size luxury car sold by Nissan's Infiniti marque from 1990 until 2006. It is a rear wheel drive, four door sedan powered by a V8 engine. Early generations were based on the automaker's Japanese-market flagship sedan, the Nissan President, while models produced after 1997 were based on the slightly smaller Nissan Cima. Exports of the Q45 ceased after 2006, but the Cima continued to be sold domestically until August 2010, when production of both the Cima and President ended. The Q45 competed directly with the Lexus LS, as well as the higher-priced BMW 7 Series, and Mercedes-Benz S-Class.
I went to Autobarn at Auburn and they did not stock or sell these. Which Autobahn did u buy from? Was there any branding on the box it came it?
Funny that. Who would have thought to use any search engine like google or even a huge site like wikipedia to search for stuff when you can just come to SAU and ask questions in the forced induction thread.
While I'm here... Why does my cat keep waking me up at 2:45am every morning?
I did google Q45 and the results I got were Infiniti Q45. I have never heard of the brand Infiniti as they do not come to Australia and I was assuming that Q45 was a code for a car or part from aussie delivered car of some sort. At the end of the day Q45 could be a part number for anything.
In short, if you have a problem with my question simply get the f**k out of my thread you wanker. We don't all know everything, if we did non of us would be here.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
