On 15.01.2015 at 11:09 AM, froggy88 said:
My 03 coupe started to do this about 8 months ago. I don't recall what error code it was throwing up (something about a faulty sensor?) but my mechanic went through the whole system and couldn't find anything wrong. They also did the reset procedure and the light came back on after about a day.
I did the ECU reset procedure and it hasn't come back on since!
Sorry for bringing it up but that problem usually occurs after sweeping, vacum cleaning under front seats either driver or passenger or just moving seats back and forward. Well known issue that causes one or few yellow SRS connectors under front seats.
You must disconnect the battery before you try to do anything with any parts of SRS system. Check all yellow connectors under both seats, unplug them, clean them up, make sure proper contacts achieved in between every connector male/female and that is it, you'll never see that problem again. Sorry once again if it was sorted already.
* reason is the age of our cars and special material japs used to plated those contacts in yellow connectors.
@Nicko_2010 Thats not necessarily anything to do with under the seats. It could be any number if sensor or as you say wire issues. Mine was the clock spring even though the signal was a seat belt warning light and I did all the checks before I even took it to a mechanic. Unfortunately you need someone with V35 diagnostics which will tell you exactly where the fault is. Some people are quoting $150 just to do that my guy charged me alot less.
I had the passenger side seat warning light a few years back, I had tried cleaning the connectors several times, using contact grease to prevent corrosion, cable tying the wires in place so they couldn't move.. each time after a few months the warning light re-occurred.  In the end I removed the pins from the connectors and soldered the pins onto the wires instead of just the crimp.  that was years ago now and I haven't had another occurrences of the fault.  I have had the clockspring go bad since then, but that threw a driver side airbag fault code, which was different to the passenger side seat.
  • 5 years later...
Guys; having run into this problem again many years after I first encountered I found one method that absolutely works every time whether its the slow flashing light or the fast flashing light on the V35 Airbag warning light.
1. Turn the key to the On position (do not start), wait for the Airbag light to go off(7 sec). Turn the key to the Off position within a second of the Airbag light going off. (& before it flashes).
Wait 4 seconds then turn the key to On as above.
2. Repeat the above 3 times - ie total of 4 times.
3. After the 4th time -when you turn the key to the Off position Wait 3 sec then turn the key On again. Wait for the light to go out. Then switch Off
4. Wait only 2 sec then turn On again. Wait for the light to go out. Then switch off.
5. Wait only 1 sec. Turn On again. Wait for the light to go out. Turn the car off. Remove key from the ignition. Then put the keys back in and start the car.
I have used the other 2 methods listed on this forum and Sometimes they work sometimes they don't. This one works without fail.
  • Like 1
On 7/6/2022 at 3:08 PM, niZmO_Man said:
how the hell do you discover something like that? Maybe the person who programmed it put it in a tech bulletin somewher
Yeah, possibly I read it somewhere years ago. But this time I just tried it without checking or looking. Also after you do these resets heaps of times you try anything!. A couple of sites do the 3sec then 2sec wait in the off position, so to me it just made sense to go that one step further!.
On 08/06/2022 at 5:47 PM, sonicii said:
I tried this at least once & it usually works, but the last time it didn't. Thats why I tried the method above. I've never seen this before..Cheers
It will only work if the fault that caused the light is no longer occurring.  This process doesn't actually fix anything, it just clears the current SRS codes.  If the fault still exists, it will just trigger the code again when the ignition is turned on next.
Yeah I know. So far so good though..
I had the exact same thing happen to my 96 R33 GTST. I tried the steps above and it only slowed down the blinking. I did find another method and it fixed it, even after starting the car several times after the fix. These steps are as follows:
Leave the driver door open when doing this. Put the key in and turn it to the ON position, then quickly press the door jamb button 10x. Turn the key to the OFF position, wait 3-5 seconds and then start the car. The airbag light should go off completely.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
