  • Replies 48
could end badly
the attessa is sensitive enough to play up with worn rear tyres, so running a staggered offset you's have to get tyres that are really close in rolling circumference/diameter
offsets would probably be ok, is it for an auto or manual? i forget now
its a manual, and after using a rolling diameter calculator, icame up wiht the following.
these are the wheels combos.
19x9.5 +11 with a 275/30 tyre, overall diameter = 647.44 mm
19x8.5 +11 with a 235/35 tyre, overall diameter = 646.93 mm
so they are quite close, if i sit down im sure i can work out some difference in pressure to bring it even closer together.... the attessa isnt that sensitive is it haha... 1.49mm difference.
YES IT IS THAT SENSITIVE. YOU ARE NOT LISTENING. Having a slight flat tyre is enough to set off the attessa, just but wheels in IDENTICAL sizes. It's not a hard concept.
Actually no. Just ignore my post again. I want you to f**k your car, maybe then you will listen.
so to get this correct in my head for when i finally buy a decent set of rims. buying rims that are different widths (ie 8.5 and 9) with different width and sidewall height (ie 235/40 and 265/40,35 or watever) will f**k it up but if i get both as for example 19 inch by 9 inch with 245/40 tyres but have the fronts as +22 offset and rears as +11 offset won't. Ignoring the fact that i've pulled these numbers out of...well you know where as far as if they will fit in the guards. The fact that the only difference is the offset means they will work....yes? because the only difference is how far the outside of the rim sits from the hub?
sigh, dont post if you have onthing imformative to say
the reason im asking questions is because i need answers, otherwise, my car would have the wrong wheels by now, there no need to be a wanker. i understand the rolling diameter issue, thats fine, i just want to see how sensitive it is. now whats wrong with changing the tyres.... couldnt i just run 245's all round, im pretty sure u can go down to 235 on a 9.5 inch rim??? so a 245 should be fine, but it would be stretched on the 9.5 so again would that change the rolling diameter???
how are there others running staggered offsets?? ive seen other stages with it done.
Edited by OMY31T
thats correct, you can run different offsets, but not a different overall rolling outer tyre diameter. the problem ive got is finding somthing unique in my budget that suits the car
Off sets don't matter, just rolling diameter, I have 18x8 with +35 fronts and +6 rears on my rs4s, I didn't realize that the manual needs same offset front and rear and the auto needs staggered offsets when I bought my rims. I'm putting 30mm spacers on my front rims when I get the time.
f**k it, i decided to buy some KOYA Endless rims. 19x8.5 and they are blanks so i can choose the offset i want. $290 a rim with whateva offset i desire.
so, to make it simple, what offset should i run all round on 19x 9.5's on a RS4S to have the wheels sit just under the guards in the rear without pumping the guards. i will most likely buy 245x35's all round for the rubber.
lol im sick of hunting, its easier to get somthing made.
ok no wories, i hope ur right hahaha.... otherwise i will be wasting over a grand :P
going off a calculator this is what ive come up with
from the stock 6 spokes which are a 7" +30 offset
with a 19x8.5 at +6 offset
i will have and extra 5mm clearance on the inner side
and have a the wheels 43mm wider on the outside.
that sounds right, because as u could see in the original pics, that the wheels sit in quite a bit. so 43mm should bring them basically inline with the guards. but im just wondering if i should go a bit higher in offset to be on the safe sifde because i dont want to get them and not beable to lower the car, and i will more than likely put in some adjustable camber items to fix up bad camber from lowering, so i think i might go a +11, because i know for a cact i have 5mm extra on the inside of the wheels from where they fit now, so the inside will be sitting the same and the outside will be 38mm wider, whcih should give me a few mm of clearance for camber correction.
Edited by OMY31T
i wouldnt go +6, u will almost certainly have clearance issues once lowered. anywhere between +10 and +15 would be the go. ive got 18x8.5+23 on mine and they could use a 5mm spacer, but im not gonna use 1 cos its illegal.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
