Which ones are you using Craig?
I use a big FO PWR one + the enlarged radiator tank and managed with a Thermal bypass. The one pictured here I used to have but I have loaned it to Iain....I'm selling the one pictured for a guy I did some work for a couple of weeks again as he will never use it.
Dasic I'll bring it down and Scott can install it at the same time as you gearbox if you want. PM me for further detail and to confirm.
cheers
Craig
Edited by Jetwreck
This one then? http://www.ebay.com....984.m1423.l2661
Fits between the intercooler and radiator I take it?
yes thats the one I have used....but it wont fit with the HDI....mine is up hidden in the front part of the bumper.
If you have a look at the picture below......the one I advertised here is the black one sitting on the top left of the FMIC. The PWR one which you have spotted on ebay you can just see running just below the bumper running around to the left.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
